20 Most Recent
Canon PowerShot A95 Digital Camera Questions & Answers
When focus the image is not clear
Focus on the nearest edges.. that will give you a "beep" sound which confirms the focus is established. You may need to turn the "beep" sound on from the settings. Hope it helps. Cheers !
My camera, a brand new
If, as you indicate, brand new return for exchange or have it repaired under Canon warranty.
How can i transfer pictures to windows 8.1
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Power wont turn on
If the camera will not power up then please check the following:
1. That the batteries are inserted correctly. Two should be facing upwards and two downwards. With the camera facing you (upside down) then the first battery on the left should have the positive terminal up, the second down, third up and last one down. If this does not work then ensure the slider switch to close the battery cover is fully closed - sometimes this sticks - as this closes a microswitch. If the camera still does not work then a fuse will have blown in the camera. This would be a very expensive repair. Hope this helps
Only settings display on lcd no image
This will either be the setting on the DISP button (back of camera) or a failure of the CCD (image processor). If the pressing of the DISP button does not restore the picture then it will be a CCD failure. The CCD failure was a common fault with the Canon A cameras and Canon repaired these free of charge up until a couple of years ago. This can be replaced by a Canon repair centre, however it will be costly. Hope this helps.
