20 Most Recent
Ricoh Aficio AP3800C Laser Printer Questions & Answers
How do I fix a ricoh afico sp 100 sc542 error
1. ATTACHED PRINTER TO COMPUTER AND TURN IT ON
2. OPEN PRINT PROPERTIES
3. CLICK ON SMART ORGANISER, IF U DO NOT HAVE THIS DOWNLOAD AND INSTALL FROM RICHOH WEBSITE
4. CLICK ON ABOUT
5. MOVE MOUSE ARROW KEY TO PICTURE ABOVE TEXT BOX INSIDE BLUE AREA
6. HOLD SHIFT AND CONTROL KEY AND DOUBLE CLICK RIGHT MOUSE BUTTON TO OPEN SERVICE MENU
>>>>> DO NOT PLAY WITH ANY OTHER SETTING OR YOU MAY PERMANENTLY DAMAGE UR PRINTER<<<<
7. CLICK ON RESET SC FUSE ONCE ONLY. (IT WILL BE SECOND LINE TOP LEFT SIDE)
8. FROM MAIN POWER SWITCH TURN POWER OFF AND AFTER 10 SECOND TURN IT BACK ON.
9. UR PROBLEM WILL BE SOLVED.
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
- Check and clean or replace the possible defective thermistors or out of position.
- Fusing heaters open circuit.
- Thermostats for open circuit.
- Power supply unit.
Good luck and please rate me, thanks.
Error code SC670
Its an over load of information by the file.
here is the actual code: SC670 mistake Engine Response
How to enter service mode in ricoh aficio 3800
Hold down the two arrow keys and count to 5, hit the enter key, the machine should be in serrvice mode if nor repeat. use arrow ke and scroll to machine press enter scroll to data log press enter scroll to pm counter reset presss enter, scroll to fuser oil press enter and exicute this mod Please. DO NOT GO INTO ANY THING ELSE or you could do serious damage to your machine!! If your machine has a Copy feature expander yopt must press Clear mode, Press 1-0-7 and then hold down the stop cancel key 4sec. go into copy sp mode press 7-804-809 press exicute button again Please DO NOT GO ANY WHERE ELSE as damag can be done to your machine. Hope this helps!!
3800C K Toner
Replace pump with new one. When this happens problem with rubber worn out
Fusing unit is not set properly
turn the printer off and reinstall the unit after it has cooled off (30 minutes). Then open cover B and D. Remove the fuser unit, then reinstall it properly. Close covers D and B. The error clears automatically if the fuser unit is properly installed.
If the error is not cleared, the fuser unit is out of order. Replace it with a new fuser unit.
SC542 error
Thats a fuser error. Thermistors needs to be replaced. Alternatively you can try clearing the code in sp mode push yellow button 107 and hold red button. Select 1 and the 5 (mode) then clear scs.
Sc556
To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look
here.
Ricoh AP3800C sc389 error code
SC389 is a development gamma error in the magenta. There can be several causes for this error - a toner supply problem, incorrect toner used, a laser exposure problem etc. This is not likely to be an easy problem to fix unless you are experienced in such matters, so you may need to look for someone who can help out.
