20 Most Recent Ricoh Aficio 2018D All-In-One Laser Printer Questions & Answers
4answers
I am getting a SC670 error I was told it was the
Hi jimsal,
Welcome to Fixya. Yes Diagnosis is correct because SC670 is a common error on this machine.
SC670 mistake Engine Response - After powering on the machine, a response is not received from the engine within 30 second. Which means when the main power is turned on or the machine starts warming up from energy-saving mode, the controller does not receive a command signal from the BCU. There could be few possibilities that you need to check and diagnose
Reasons:
- Loose connection
- Defective controller
- Defective BCU
Troubleshooting:
- Turn the main switch off and on.
- Check the connection between the BCU and controller.
- Replace the controller.
- Replace the BCU.
Here's the illustration of the controller:
To reinstall the controller board into the printer push the bottom center area of the board
After replacing the BCU or controller, remove the NVRAM on the old board and put it on the new one.
This should be the series of troubleshooting. Unfortunately, this is not an easy fix. If you do not have any repair experience, i would advise you to call a Ricoh professional so that he could take care of the problem.
Thanks for using Fixya.
4/18/2020 10:39:10 AM • Ricoh Aficio... • Answered on Apr 18, 2020
3answers
Error 36851: No response from scanner" ricoh
Dear kishorkamble, We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options: 1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4 2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP I hope it may be useful. Yours sincerely, Bruno Coutinho
2/1/2020 9:53:06 PM • Ricoh Aficio... • Answered on Feb 01, 2020
4answers
I want drivers for ricoh
Below is a link to the driver download site for your Ricoh Aficio 2018D Laser Printer. Please note that although these drivers are still available for download, official technical support for this model has been discontinued.
To download the drivers, click the following link:
http://support.ricoh.com/bb/html/dr_ut_e/re/model/x2015_18/x2015_18en.htm
If you found this solution helpful, please leave a positive rating!
4/18/2018 9:19:06 PM • Ricoh Aficio... • Answered on Apr 18, 2018
My ricoh aficio 2018 printer ran out of toner and i installed new toner but it prints blank copies.
sounds like photo conductor is bad will need to rebuild or replace it
3/22/2017 11:37:58 AM • Ricoh Aficio... • Answered on Mar 22, 2017
2answers
How do I cancel a print job sent to the Ricoh
You may have to go to the printer and click on Status or printer jobs and cancel the job from the printer. It appears the printer has the whole job already spooled in memory
8/5/2016 10:26:01 AM • Ricoh Aficio... • Answered on Aug 05, 2016
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/25/2016 7:13:01 PM • Ricoh Aficio... • Answered on Jan 25, 2016
2answers
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
1/19/2016 12:50:56 PM • Ricoh Aficio... • Answered on Jan 19, 2016
Paper coming out on an angle in delivery tray roller not feeding paper evenly!
You have a broken part: AA08-0342 is the part number. It can't be easily replaced. I hope you are skilled enough. My advise is to find technical person. Pifonski
12/7/2015 7:59:19 PM • Ricoh Aficio... • Answered on Dec 07, 2015
How do you open the drum unit on an oficio 2018d
my dear you first side door open after you frand door open and remove drum unit
9/2/2015 8:37:13 PM • Ricoh Aficio... • Answered on Sep 02, 2015
Just after fuser unit, gears
Go to company website and click on product support.
4/12/2015 10:15:27 AM • Ricoh Aficio... • Answered on Apr 12, 2015
Sc 901 ricoh 2018d
901 B Mechanical total counter The mechanical total counter does not work properly. • Mechanical total counter defective • BICU defective • Disconnected mechanical total counter
3/31/2015 11:45:00 AM • Ricoh Aficio... • Answered on Mar 31, 2015
HOW MANY WATTS DOES THIS MACHINE HAVE IM TRYING TO USE A 1440 WATTS INVERTER AND 24 V BATTERY ITS FAILING TO INITIALIZE??
With a 1440 watt and 12 volt, the battery must be over a thousand AH. (ampere/ hour) because for the 1440 watt, you need a current of more than 100 ampere. But even with a few hundreds of watt, you need a very powerful battery, because 300 watt, will pull 30 amps from the battery. A car battery with even 100 AH can't deliver that.
3/23/2015 3:28:10 PM • Ricoh Aficio... • Answered on Mar 23, 2015
2answers
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
2/24/2015 3:53:37 AM • Ricoh Aficio... • Answered on Feb 24, 2015
Set the number of rings before the fax machine picks up
copier doesn't have this feature. mp 161 has it called rx mode auto switch time
10/10/2014 11:45:04 AM • Ricoh Aficio... • Answered on Oct 10, 2014
2answers
Fax confirmation
Hi TUlsi The majority of fax machines will do this, I know as the ones i use in DHL are the same when i contacted the company Cannon they advised that it could not be disabled. Which give the solution, All faxes are different and you will only know how to disable it by contacting the manufactures support. I agree full it is anti enviromently friendly and a waste of ink
9/2/2014 1:07:39 PM • Ricoh Aficio... • Answered on Sep 02, 2014
0answers
3answers
Ricoh aficio 2018d error sc302 can someone please
The manual says that this is a chage roller leak.
Means the the high voltage is arching to ground or drum somewhere....usually pinhole in chage roller
5/26/2014 9:23:19 AM • Ricoh Aficio... • Answered on May 26, 2014
0answers
Ricoh Aficio 2018D All-In-One Laser Printer Logo
145 questions posted
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
error sc553
  • Office Equipment & Supplies
