20 Most Recent
Ricoh Aficio CL7000 Laser Printer Questions & Answers
How to enter service mode on ricoh mpc5503
To access service mode on the new Ricoh MFCs (those ending with a 3 . . like MPC 3003, 5503, 6003 and so on.. ) you type the following:
Reset (yellow button), 8-0-6-1-8-2, then push (and hold) the Clear Button (C) until you can see in the display that you have accessed service mode.
Printing a Booklet on a Ricoh Africio 3260C
first you need to use the RPCS printer driver supplied by ricoh. Second then go to printer properties box and then select the tab for finishing, you should then see the options for booklet printing, if the option are not there you have to add the finisher in the printer driver as an option
http://www.websitetoolbox.com/mb/copierquestions
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
