20 Most Recent
Nikon Coolpix L120 P300 Lens Unit Assembly Repair Part Questions & Answers
The stereo eyepieces are dark,
It might be that Objective lens is not seated properly or very dirty. So perhaps by rotating the objective block may help before trying to clean it. Also try to start with the lowest magnification to see that you have functional microscope before trying higher magnifications. Good luck.
I'm using the Nikon ECLIPSE
There are a few things that could cause a shadow in the field of view.
First if the condenser is not centered, this can create a crescent shaped shadow and rob your image of light. Center the condenser and raise it to within about a 16th of an inch from the top of the stage.
Second, the slider on the head which diverts light from the eyepieces to the camera must be fully engaged to the "camera" position
Third, make sure that the diaphragm on the condenser is not closed too far. There is an adjustment ring for this. Set it to 70-80% of the numerical aperture of the objective you are using.
Fourth: if there is a "swing out" condenser lens you will need it completely in or out depending on the objective you are using. for 2x-5x you need the swing out condenser lens completely out of the light path. For objectives 10x and up you need the swing out condenser lens completely in and centered in the light path.
If these things are properly adjusted you should not have a shadow in the field of view. If you still have a problem, let me know.
We are using our Nikon Eclipse e200 for the first
If this is a brand new scope then there is most likely some packaging or packaging tape that is preventing movement. Scopes are meticulously packaged because they can be rather delicate instruments. In some rare cases the scope may be damaged in shipment.
Service for Nikon Esclipse E400
You can locate an Authorized Nikon Repair Center for India at the following link:
http://www.nikon-asia.com/distributors.php
