20 Most Recent
5.5hp 6:1 Gear Ratio GX160 Engine Questions & Answers
I need to replace piston rings in 5.5hp 160
Hi, the flywheel should be held on with a large nut to the crankshaft.
You need to loosen the nut but DO NOT REMOVE the nut. The crankshaft should have a small amount of back and for movement, place a lever behind the flywheel and apply pressure to the lever in the direction of the nut, I.E. away from the body of the engine. Using a soft hammer (copper) give the nut a solid hit, this should dislodge the F/w off its taper.
Lightbulb replace hondaaccordradio1998
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Gx610 Honda v-twin small engine one side want fire
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
