20 Most Recent Samsung SF-650 Laser Fax/Copier Questions & Answers
3answers
My fax machine will send a fax, but I can't receive a fax?
The fax machine may be in secure receiving mode. The following is from the User's Manual section on Faxing. downloadcenter samsung com
Receiving in secure receiving mode
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Activating secure receiving mode
  1. Press btn_fax.png(Fax) on the control panel.
  2. Press Menu until Advanced Fax appear.
  3. Press the left/right arrow until Secure Receive appear and press OK.
  4. Press the left/right arrow until On appear and press OK.
    You can activate secure receiving mode without setting a password, but cannot protect your faxes.
  6. Re-enter the password to confirm it and press OK.
  7. Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received. Printing received faxes
  1. Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
  2. Press the left/right arrow until Print appear and press OK.
  3. Enter the four-digit password and press OK.
    The machine prints all of the faxes stored in memory.
Deactivating secure receiving mode
  2. Press the left/right arrow until Off appear and press OK.
    The mode is deactivated and the machine prints all faxes stored in memory.
  4. Press Stop/Clear to return to ready mode."
1/17/2017 6:10:06 AM • Samsung SF-650... • Answered on Jan 17, 2017
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red. Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.) Is the self-cleaning prompt in the Easy Printer Manager? Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges? I have now wiped them Technician's Assistant: Anything else you want the Printer Expert to know before I connect you? How do I start the self-cleaning cycle?
4/14/2024 10:49:58 PM • Samsung Office... • Answered on Apr 14, 2024
3answers
Lsu unit failure:#u2-1112.please turn off then on
what is this unit
3/18/2024 6:12:50 AM • Samsung Office... • Answered on Mar 18, 2024
Android phone can control Samsung amplifier?
Question edited for clarity and correctness. An HE-560 appears to be a pair of headphones? https://www.google.com/search?q=Samsung+amplifier+HE-560 And it is not a 's2 (space) 3 ultra'. It is a Samsung S23 Ultra (added CAPS). Here are the specs https://www.samsung.com/ca/smartphones/galaxy-s23-ultra/specs/ Advertising https://www.samsung.com/ca/smartphones/galaxy-s23-ultra/ Unfortunately, the answer is No, great phone, but No. ..
3/14/2024 6:21:30 PM • Samsung Office... • Answered on Mar 14, 2024
2answers
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
  1. Go to Settings > Devices > Printers and Scanners.
  2. Find your printer in the list, click on it, and select Manage.
  3. Click on Printer Properties.
  4. In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
2/21/2024 8:46:19 AM • Samsung Office... • Answered on Feb 21, 2024
Samsung cassette error 451
Error 451. Low Pressure Switch Low Pressure (Protection Control)
Samsung VRF Air Conditioner Fault Codes
samsungvrf.com.tr https://www.samsungvrf.com.tr > samsung-vrf-klima-a... Fan Controller 1 Lock error. 450, High temperature every time (protection control). 451, Low Pressure Switch Low Pressure (Protection Control). 452, Instant ...
SYSTEM AIR CONDITIONER
Amazon https://s3.amazonaws.com > Service_Manual PDF Error of impossibility to operate heating at outdoor temperature exceeding 30°C : E440. Error of impossibility to operate cooling at outdoor temperature of -5°C ... 116 pages
Samsung Air Conditioner Error Codes
Luce Aircon https://www.luceaircon.sg > blog-article > samsung-air... Feb 20, 2021 - Decode Samsung AC error codes with our comprehensive list. Identify and troubleshoot issues affecting your unit for optimal performance and ... https://www.google.com/search?q=Samsung+cassette+error+451 ..
2/15/2024 12:05:07 AM • Samsung Office... • Answered on Feb 15, 2024
2answers
Download bixolon stp-131 ig driver
i need driver stp-131p
2/7/2024 10:49:49 AM • Samsung Office... • Answered on Feb 07, 2024
Because the Samsung ML-1865W printer takes time to pull the sheets
It takes time to send the sheets through because the processor is not as fast as other printers.
12/17/2023 7:43:24 AM • Samsung Office... • Answered on Dec 17, 2023
Tell my Samsung SCX-4521F printer IP Address.
It is assigned if you have it on a network.
SAMSUNG SCX-4521F SERVICE MANUAL ' Manualzz
manualzz.com https://manualzz.com > ... > Print & Scan Ping command can see the printer. If an IP address is not allocated to the printer or it is in a different. LAN segment then ensure that either IPX/SPX or ...
Setting Ip Address - Samsung SCX-4500W User Manual ...
ManualsLib https://www.manualslib.com > ... > User manual In a few situations the IP address must be set manually. This is called a. static IP and is often required in corporate Intranets for security reasons. ..
12/2/2023 8:11:37 PM • Samsung Office... • Answered on Dec 02, 2023
2answers
My printer spoler is not working
Hi g k,Have you tried restarting the print spooler from services?Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler net start spooler exit Note Press ENTER after each command line.
Hope this helps, and please rate:)Gary
11/1/2023 4:38:20 PM • Samsung Office... • Answered on Nov 01, 2023
How to scan to pc on samsung ML-191x 252x series
Install the printer/scanner software and use the menu system.
10/26/2023 4:42:36 PM • Samsung Office... • Answered on Oct 26, 2023
My Samsung ml-2165 printer showing fuser unit failure ,error u-1-2120 ,what can I do
Visit following website and run printer diagnostic. It may help you Samsung ML-2165 Laser Printer series - Troubleshooting ' HP® Support
10/20/2023 12:30:57 PM • Samsung Office... • Answered on Oct 20, 2023
Samsung ML 191x turns on for two seconds, then turns off. Any suggestions?
Visit HP Official website Samsung ML-2525 Laser Printer series - Troubleshooting ' HP® Support In the troubleshooting section, run the Printer Diagnostics.
10/11/2023 12:58:43 PM • Samsung Office... • Answered on Oct 11, 2023
My Samsung SCX-3405F printer stays in "system initialize". I re-installed the printer drivers that I received with the printer. Please assist.
I suspect a loose or damaged paper roller. It might need reseating. Make sure that all the rollers are intact and close all printer doors firmly
8/27/2023 1:57:54 PM • Samsung Office... • Answered on Aug 27, 2023
Samsung SF-650 Laser Fax/Copier Logo
2 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
fax machine will send fax but receive
  • Office Equipment & Supplies
