20 Most Recent
Proform Crosswalk 395 Treadmill Questions & Answers
When on treadmill there is a "studder"
Check if the running belt is lubricated. You can't run an engine without oil. So, spray a good quality silicone lubricant on the base of the running belt. It is best if you spray on a lint free cloth just enough to make a wet patch. Do it outside so that no spray residue lands on the floor and becomes slippery or lands on the carpet and stains it, then return inside and lift the treadmill running belt and soak or smear the base with the wet patch of the cloth and run for a full minute. Then lift the belt again and give it another swipe on the entire base, then feel the base with your fingers or hand to see if it feels wet and smooth. Run the treadmill for another minute at slow speed, otherwise the liquid can fly and splatter on wall or floor. If it still hasn't solved the problem, then it must be the motor brushes, or it may be set to run slow and fast according to the running settings on the console. Mine does the same thing if it is programmed to do 1 minute slow and one minute a bit faster. Good luck.
8/1/2014 3:42:40 PM •
Proform...
Answered
on Aug 01, 2014
Belt keeps sliding from side to side
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
3/10/2014 10:57:54 AM •
Proform...
Answered
on Mar 10, 2014
