20 Most Recent Nikon Coolpix S3300 Questions & Answers
It is mostly due to changing the exposure compensation. You can change it from +2 ....0 ....... -2. +2 Makes it Brighter while -2 makes it darker... On the back of the camera you will see an OK button surrounded by a disk that on the right side shows [+/-]. You use this to change exposure compensation. When you get the camera READY to take a photo you can use that [+/-] button. When you push it you can adjust it to zero (o) normal or to make it lighter or darker.
Nikon Coolpix... | Answered on Jun 29, 2018
If you didn't switch off the camera before removing the card, you have probably corrupted the data on the card.
Nikon Coolpix... | Answered on Sep 27, 2017
Power off, remove sd card and power on. Then reinstall sd card and you can start over.
Nikon Coolpix... | Answered on Mar 18, 2017
Replay will give a WARNING NO IMAGES. This is confusing. I can think of nothing to do. Turn it off off remove Batteries. Put batteries back in an CHARGE IT... Make sure it is FULLY CHARGED. Then Remove from charger and turn on and take a photo Does REPLAY WORK?
Nikon Coolpix... | Answered on Mar 02, 2017
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Nikon Coolpix... | Answered on Feb 05, 2016
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Nikon Coolpix... | Answered on Jul 20, 2015
Did you switch to the display mode? check the manual to see what button you should press.
Nikon Coolpix... | Answered on Mar 23, 2015
These camera's will do that when the battery is very low sometimes.
I'm not sure that is your problem due to lack of more details, but it is a possibility.
Nikon Coolpix... | Answered on Mar 12, 2015
The videos should be showing up just like a photo does and when the video is brought up using the replay button, just use the delete menu to delete it.
Nikon Coolpix... | Answered on Jan 01, 2015
Call Nikon Service at 1-800-645-6687 between 9AM and 8PM EST, Monday to Friday. They will provide you with the information you need to get it repaired along with approximate cost.
Nikon Coolpix... | Answered on Dec 25, 2014
is it only the view finder or does it appear on the photo as well because if it the view finder then it is the screen and if it is on the photo as well then its most likely the lense and once you have deterined this then you can know if it is just dirty or if the screen needs replacing
Nikon Coolpix... | Answered on Nov 27, 2014
then the best thing to do is to take it back to the place you bought it from and let them sort it out for you as when you open the item it voids that warrenty and then you will have to pay for any repairs needed
Do you really need a driver?
Nikon Coolpix... | Answered on Sep 23, 2014
Coolpix s3300 does not have any other viewfinder, your LCD panel is your only viewfinder. By default it cannot be turned off.
Please provide more informations so that I can help you.
Nikon Coolpix... | Answered on Sep 21, 2014
Use a high speed card, i guess u are using an ordinary card. Also if possible update the camera firmwire. It can be obtained thru nikon sites along with instructions
Nikon Coolpix... | Answered on Sep 16, 2014
Nikon Coolpix S3300 Logo
113 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
wonderful coolpix recently seems letting
  • Cameras
