20 Most Recent
Seiki SC221FS 22 Class LCD HDTV Questions & Answers
Green tint on tv
Is entire screen green or just tint range will not move?Look at set with color off to zero and also try different inputs.Advise me source of signal and how or where you are connected.
Seiki
hi,the first thing to check with this kind of problem is the power supply section.this requires opening of the back cover.If you are handy with electronics you can check the voltage present at the power board by using a digital multimeter..here's the procedure,Use a philip screw driver to unscrew the cover.once the cover is remove,you can immediately see the power supply board .Powe supply board is where the power cord is connected(make sure to unplug the unit before proceeding)check the fuses,set the tester to resistance or continuity test.test the fuse you must have a reading of 0000 this means that fuse is good OC means fuse is open.replace the fuse with the same type of amperage it is printed on the fuse...If the fuse are ok,check for the voltage output of the power board.voltage are as follows,5 volts DC supply for the mainboard12volts DC for the audio board24 volts DC for the screenwhen all this voltages are present problem could be on tha mainboard itself and needs a replacement.If one of the voltages fails then you need to repair the power board check and replace all bulging capacitors and open resistors.you can also replace the whole powerboard It is available online at shoppejimmy.comgood luck and let me know how it goes..
I am trying to connect my Nintendo Entertainment System to my Seiki TV, but it's not working.
It's possible that the connection between your Nintendo Entertainment System and Seiki TV isn't properly set up. Here are some steps you can try:
- Ensure that your Nintendo Entertainment System is properly connected to your Seiki TV. You can use the red and white AV jack to connect the audio cables, and the yellow jack to connect the video cable.
- Once you've made sure that everything is connected properly, turn on both your Nintendo Entertainment System and Seiki TV.
- On your Seiki TV, go to the "Input" or "Source" button on your remote control and select "AV" or "Composite" as the input source.
- If your screen still flashes black and blue, try unplugging and plugging in the cables again, making sure that they are securely connected to both your Nintendo Entertainment System and Seiki TV.
- If you're still having trouble, try using a different set of AV cables, as the cables may be damaged.
If none of these steps work, it's possible that either your Nintendo Entertainment System or Seiki TV is not working properly. You may need to seek further technical assistance to diagnose and fix the problem.
How do I reverse an upsidedown picture on my SEIKI TV
To reverse an upside-down picture on your SEIKI TV, you can try the following steps:
Press the "Menu" button on your SEIKI TV remote.
Use the arrow keys on your remote to navigate to the "Picture" menu.
Scroll down to the "Picture Rotation" option and select it.
Use the arrow keys to rotate the picture until it is right-side up.
Press the "OK" button on your remote to save the changes and exit the menu.
If the above steps don't work or if you can't find the "Picture Rotation" option in the menu, you can also try physically rotating the TV screen by 180 degrees. This may be necessary if the TV was mounted upside down or if it was accidentally rotated.
Keep in mind that the location of the "Picture Rotation" option may vary depending on your specific SEIKI TV model. If you can't find the option, consult the TV's user manual or contact SEIKI customer support for further assistance.
How to I flip the picture on my SEIKI SE32HY10 LED TV
To flip the picture on your SEIKI SE32HY10 LED TV, you can follow these steps:
- Press the "Menu" button on your TV remote.
- Use the arrow buttons to navigate to the "Picture" or "Display" menu.
- Scroll down to the "Picture Mode" option and press "Enter".
- Select the "Flip" or "Invert" option from the list of available picture modes.
- Press "Enter" to save your changes and exit the menu.
If your TV doesn't have a "Flip" or "Invert" option in the Picture Mode menu, you can try accessing the Service Menu to see if the feature is available there. However, accessing the Service Menu requires specific codes and steps, and any changes made in this menu can affect the TV's performance, so it's recommended to do so only if you're experienced in TV repair or have professional assistance.
