20 Most Recent Beverage-Air 23.1 cu. ft. / 654 liter Commercial Freezer BEVEF-24S Questions & Answers
some time they have been water lecking down and freezing and swelling the bottoms out. if this is the case then you cant fex the sides of the freezer.
Beverage-Air... | Answered on Mar 27, 2013
First, the freezer coils have a temperature sensor strapped to it with a copper band.
The fans won't come on until the coil is under 10 degrees. Second, the fans won't come on if the doors are open. The same switch that shuts off the insdie light also turns off the fans. Try those two items. If the coils never get cold enough the fans simplhy won't come on at all. You may have low refrigerant or the other coils out by the compresor may be clogged with dust or grease.
Beverage-Air... | Answered on Sep 26, 2010
You probably have a freon leak and the compressor is cutting out on low pressure.... then it stops... the pressure builds and it starts again... it will kill it's self doing that...get it serviced right a way...
heatman101
Beverage-Air... | Answered on Aug 07, 2010
Since this is a freezer, it should have a defrost terminator/ fan delay. This could have gone bad or you may have a refrigeration problem. Such as low on freon due to a leak. Need more info, I'll explain in detail. Let me know. Will Be more than happy to.
Beverage-Air... | Answered on Aug 24, 2009
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
Beverage-Air... | Answered on Feb 09, 2009
What does ( da ) mean on a beverage two fan single door reach in frezzer disply
Beverage-Air... | Answered on Aug 08, 2015
Most all manufacturers try to build units to hold between 34 to 38 degrees as this is the most commonly accepted range for coolers by all Health Departments.
Beverage-Air... | Answered on Oct 06, 2010
dirty condencer coils bad fan motor or compressor start relay on the side of compressor or turned off then back on without waiting 5 min.
Beverage-Air... | Answered on Dec 09, 2009
unplug it and wait 10 min, then plug in. That may reset it.
If not, observe the flashes of the light as it may be giving you a code to lookup. - like it will flash 3 times, pause, then flash 5 times, then pause longer, the repeat.]
lookup error code 35.
Freezers | Answered on Dec 04, 2019
Google (hisense)(FT124D4HW1)(manual) without parens for instructions.
Freezers | Answered on Nov 30, 2019
Here is semi hermetic Copeland video.
Freezers | Answered on Nov 24, 2019
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwi7pKGDs-jlAhVZu9UKHV44CDsYABAAGgJ3cw&ggladgrp=16324162528486679138&gglcreat=6332738198550685945&ohost=www.google.com&cid=CAESQOD2oPaVJ6ueDrtkdJSj-w-Bs0iYUPSLB9-TPdnBxIHydvXnRBEdgBXvFCtTMMMxJhly6R_M8pbrUqQMX2vwol0&sig=AOD64_26o6XlEuS5VN3O22DexXqdQRwp3A&q=&ved=2ahUKEwinypODs-jlAhXMAWMBHcZjBfoQ0Qx6BAgNEAE&adurl=
Freezers | Answered on Nov 14, 2019
Call 1-800-673-1262
Freezers | Answered on Nov 02, 2019
Beverage-Air 23.1 cu. ft. / 654 liter Commercial Freezer BEVEF-24S Logo
5 questions posted
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Michael Youngman
Michael Youngman
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Freezers
Most Popular Question
evap fan will not come jumped out fan
  • Freezers
