20 Most Recent
D-Link DI 707P (DI-707P) Router Questions & Answers
Bi-directional
D-Link´s print servers are IEEE1284 bi-directional compatible. This means that data can be sent and received in both directions between the printer and the D-Link print server. Toner status, paper level, and etc. will not be communicated back to the PC. In order to get printer status information, the proprietary printer driver has embedded code that needs to be passed on to the print server, decoded, then interpreted by the print server. Embedded driver codes are not supported by D-Link print servers. D-Link´s print servers, whether in Gateways or StandAlone, are plain TCP/IP print servers.
Print server software for mac
There are no plans to have Macintosh software for the print server feature of our routers.
If you can perform port-based printing (OSX), you do not need printer software. Just print to the IP of the router (default is 192.168.0.1) and the Print Queue Name is lp (a lower case "L" and a lower case "P"). Use the current drivers for your printer. In some cases you made need postscript drivers for your printer from the manufacturer (if available). This feature is not supported by D-Link, as per packaging.
Please visit http://gimp-print.sourceforge.net/MacOSX.php3 for 3rd party drivers that may work with your D-Link router. D-Link does not and will not support these drivers. Use at your own risk.
Do not keep the product in anticipation of Macintosh compatibility. Return it to your reseller.
Can´t print through the router print server
Try changing the Spool Data Format setting in the printers control panel from EMS to RAW.
Step 1 Go to Start>Settings>Printers.
Step 2 Right click your printer icon and select Properties
Step 3 From the properties screen, select the Details tab. Click on the Spool Settings button at the bottom of the window.
Step 4 From the Spool data format: select RAW from the drop-down menu. Click OK to close out of Spool Settings and OK again to close out of the printer properties screen. Close the Printers control panel and try printing to the DI-713P with these new settings.
In some cases, you may need to disable bidirectional printing.
Scheduled Firewall
Unfortunately not. Active connections must be stopped before the rules take effect.
For Example: If you have an active FTP download when the schedule takes effect, the session will not be terminated until the download is complete. Once the schedule is effective and the FTP download has completed, you will not be allowed to initiate another FTP connection until the scheduling permits.
AOL DSL Plus
AOL DSL+ now uses PPPoE for authentication bypassing the client software.
To set up your router:
Step 1 Log into the web-based configuration of your router by opening a web browser such as Internet Explorer or Netscape and enter the IP address of the router (192.168.0.1). Enter admin for username and then your password (blank by default). Configure the WAN side to use PPPoE. Please consult your manual for login instructions since all routers are not the same.
Step 2 Enter your screen name followed by @aol.com for the user name. Enter your AOL password in the password box.
Step 3 You will have to set the MTU to 1400. AOL DSL does not allow for anything higher than 1400.
Step 4 Apply settings.
Step 5 Unplug (turn off) the power to the modem and router. Wait 1 minute and then power on only the modem. Wait about 1 minute and then power on the router.
NOTE: If you connect to the Internet with a different Internet service provider and want to use the AOL software, you can do that without configuring the router?s firewall settings. You need to configure the AOL software to connect using TCP/IP (LAN). Contact AOL for more specific configuration information of their software.
Configure to print
You may print without the D-Link Printer software in Windows 2000/XP. Here´s how:
Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer).
Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next.
Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next.
Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next.
Step 5 You will get a message saying that additional port information required.
Step 6 Select Custom and then click Settings.
Step 7 Set Protocol to LPR.
Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this.
Step 9 Select OK > Finish.
Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
