Check the LAN cable between the router and the internet modem and try another cable. Obviously rebooting both is orth a try.The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Why is the D-Link Router not working anymore?
Before you continue and be ready with full attention to fix the D-link Router and follow these steps:-
l Reboot Your modem and wait for 1 min.
l Then reboot your router and wait for 2-3 min
l Make sure modem to router connection and cable is connected.
l Try connecting the modem with the computer directly just to make sure internet service provider (Modem ) side giving you internet.
D-Link router is a good service provider and there are service charges nothing more, it's are very satisfied service according to the customer. If the user wants to contact our toll-free number or visit service number website and get any kind of technical solutions.
https://servicenumber.org/d-link.html
Sir
I suggest You watch below you tube video for D-Link AirPlus DI-524 Wireless Router configuration to resolve your D-Link AirPlus DI-524 Wireless Router Issues,
Link AirPlus DI 614 Wireless router 100
Or
in case you still having D - link Router Problem Then follow Us On for Online D - Link Router Setup Support By Our online D -Link Router Technician on Below Mention Link URL website,
http://www.techsupportrouter.com/support-for-d-link-router.html
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Then make certain all your devices login to the wireless network with the SSID and Key.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset.
This many times fixes issues like your described.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Login in using your browser using a LAN cable and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method. I would change the network name (SSID) if people have connected to your router before and hide (do not broadcast) so they will not see it on their WiFi devices.
