20 Most Recent
CardScan Dymo Rhino 6000 Thermal Label Uses 1734519 Mono Printer Questions & Answers
When I scan a card a message pops up that LEADTools is not installed. Why?
LEADTOOLS is an SDK (Software Development Toolkit) that Software Developers can use in their applications. It sounds like the manufacturer of the Scanning Software that you are using is not deploying all the necessary LEADTOOLS files that are required to run the program. You can try uninstalling the software and then reinstalling to verify that it was not an installation error, but if it still is not working, you will need to contact the manufacturer of the software and let them know you are getting these errors.
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
How to change tax rate on spl-290 calculator
* Press *N/C/CE *****n* Enter 200* Press the TAX+ *****n* The display will sh*w the t*tal price TAX+ 210* Press the TAX+ *****n again* The display will sh*w the tax am*unt TAX 10* *r the price after tax is $58.5, what is the pre-tax price and tax am*unt:* Press *N/C/CE *****n* Enter 58.5* Press the TAX- *****n* The display will sh*w the pre-tax price TAX- 55.72* Press the TAX- *****n again* The display will sh*w the tax am*unt TAX 2.78
My conlog is showing minus - 11.06 kwh
You mentioned a reading of minus 11.06 kWh. Here's what it means:
Remember that this is a prepaid meter, so the negative value suggests that you've used more energy than what was prepaid
The meter has consumed 11.06 kilowatt-hours (kWh) more energy than it has generated or received.
This negative value indicates that more energy was used than supplied during the specified period.
LED Indicator:
The meter has an LED light that flashes when electricity is consumed.
When you use electricity, the meter balance decreases, and the LED light provides a visual indication of energy flow.
