20 Most Recent
Champion G5NG853S 540 Watts Juicer Questions & Answers
Cleaning inside the cutter
I've been using my Champion for about 20 years, and have always used a very thin coat of olive oil on the turn shaft before sliding the cutter on. I've also used it before I've used the grain mill, and it has been fine.
If I were you, I think I would get out as much Crisco as I could with a chopstick (or something similar), put in some liquid soap, and some hot water. I would think that would loosen anything that was compressed or stuck. It might take a few times, but that's what I would try....or you could order a new cutter from Champion. I've had to order parts from them in the past, and they have been great.
Hope this helps.....
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
Do you offer problem resolution
Yes... just as you posted this just post you question...
There is both pay and free questions...if you pay you will probably up the odds of you getting your answer faster... :-)
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYaheatman101
