20 Most Recent GE PFSS9PKy Refrirator Questions & Answers
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
GE PFSS9PKy... | Answered on Nov 11, 2012
DEFROST TIMER IS STUCK IN THE ON POSITION CALL LOCAL REPAIR SERVICE
GE Refrigerators | Answered on Dec 03, 2019
The cause is the digital display is not communicating with the motherboard. The plug connection between the door's digital display and the motherboard might have unplugged. The wire running from the motherboard runs below the fridge and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. Just reconnect it and that should reset the display.
GE Refrigerators | Answered on Nov 29, 2019
I had the same problem. The cause is the digital display is not communicating with the motherboard. What had happened in my case is the plug connection between the door's digital display and the motherboard had become unplugged. The wire running from the motherboard runs below the fridge, and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. I just reconnected it and that reset the display. Glad for it too, I thought I needed a new $130 motherboard! Hope this helped!
GE Refrigerators | Answered on Nov 28, 2019
LOOK AT IT REAL GOOD AND SQUEEZE THE SIDES
GE Refrigerators | Answered on Nov 13, 2019
need more info on unit .how old ? and model would be helpful
GE Refrigerators | Answered on Nov 10, 2019
sounds like the cutting grid is broken .look at grid and see wire broke .if it is you will need a new cutting grid.
there is a connection bottom of freezer door ,behind kick plate .remove kick plate look at connection see if its has corroded . that is where the problem is.
You still may be able to get a thermostat (i'm guessing that's what he's calling the cold control). Get your model number and hit the internet. Go page by page. It will be tedious but you may get lucky. Try every appliance part site that shows up. Sometimes o.e.m. parts sit in warehouses for years before they're sold if ever. You might find a brand new one. Also, check with your local appliance recycler. Sometimes they have good used parts.
GE Refrigerators | Answered on Nov 05, 2019
GE PFSS9PKy Refrirator Logo
2 questions posted
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
filter light will not turn off
  • Refrigerators
