20 Most Recent
Nokia Lumia 710 Questions & Answers
Aircel puk code online
Hi sir,
for Aircel PUK code u have to contact with your service provider ..talk with customer care and ask for the PUK code ..just in case your number is blocked so u can use any other number of same service provider.
How to find PUK code for Aircel sim card
It is very easy to get the PUK, all you have to do is just call Aircel Customer care through your another Aircel number or from your friend mobile who are using Aircel.
Before calling customer care make sure you have
1.The 8 -15 unique number printed on your sim card, Incase if you dont have it on your simcard you may find it in the cover pack which comes with new sim card.
2.The name of the owner of the sim, owner means the name which you have given when you are buying the new sim.
3.There are some rare cases where they ask about the last recharge amount or date.
Thank you
Abhishek Gautam
How to reset or recharge nokia lumia 710 mobile phone
That phone is junk and the battery life is very limited...
Just get a new battery or throw the phone out....
You can try resetting the phone to the default factory settings....but it's not worth the headache..the phones resale value is about $10....now. cheers
P.S. I know because I had one.... chucked it in the bin..
Cannot delete Skydrive photos on phone
HiTerry.
Never used Skydrive myself but try this:
Plug phone into computer.
Set phone up as mass storage device if it doesn't recognize.
You may have to install your phone's software from disk onto the pc.
or
Get hold of a card-reader and plug your phone's SD card into it.
From the pc, navigate to the phone or card-reader.
Then using explorer, delete photos.
O2 sim on nokia lumia. Possible or not
If your Nokia Lumia 710 is free from network restriction or locked to O2 network, you can definitely use your O2 SIM card with it. If your Nokia Lumia 710 is locked to some other network, you need to unlock it in prior. You can unlock a Nokia Lumia 710 safer and easier using unique unlock code. You can get the unique unlock code for a Nokia Lumia 710 from
Unlocking4U.com at affordfable cost with an easy unlocking guide. Good luck.
NETWORK PROBLEM NOKIA 710
If you are still under warranty period, you can get it replaced. Or else get it rectified from any nearby Nokia service center.
Unable to reply to text messages ?
you must be typing the name of the recipient instead of selecting them from the Contacts. You may type but as the name appears from Contact list, do select that.
Why is my text message feature not showing on my screen?
Go to the Start Screen by pressing the Start Button. Then Swipe left to show all the Apps installed on your phone. Scroll Down by sliding up your finger to find the Messaging app.
To add the app to your Start screen, hold the App's name, and then select Pin to start from the pop up menu that comes.
