20 Most Recent Samsung RV520 Laptop Questions & Answers
It would be great to know how much memory does the laptop has. Usually browsers do take a lot of memory, so if you have limited amount of memory, of course your laptop will slow down and freeze.
I suppose you are running windows.
But you can also monitor and check if the cpu use 100% of it and will also let you know what is causing the cpu to use 100%.
Just search Why is my laptop using 100% cpu
Samsung RV520... | Answered on Jun 28, 2017
things that happen to older laptops are that over time there tiny processor power supplies build up with lint from the air that is passed thru them sometimes even making the tiny cooling fans in there stop , then its only a matter of a few minutes and it overheats and shuts off , after several hours cool own it will restart , but wont stay on long , then the cycle repeats . if its caught in time and no power supply parts are ruined sometimes a Pc repair shop can dismantle one and clean it
Samsung RV520... | Answered on Dec 03, 2015
http://www.fixya.com/support/t23209208-remove_bios_password_samsung_rv520
Samsung RV520... | Answered on Mar 25, 2015
Overheating? Are the airways clear and is the fan clear?
Samsung RV520... | Answered on Feb 28, 2015
There may be a loose connection of the cable charger
Samsung RV520... | Answered on Aug 18, 2014
go to the samsung website and find the drivers section. you should be able to re-install what was deleted there
Samsung RV520... | Answered on Apr 02, 2014
It's very common when installing Windows 7 for you to get to the Windows logo or blue windows screen and it be blank and you sometimes have to wait for anything up to 15-20mins before the installation options appear, unsure why this is but make sure you allow 30mins on that blank screen before righting it off... You also need to decide if your setting up a dual boot system if you already have XP on their, if you want to keep both then select dual boot when installing. Sorry it's not an answer but waiting 15-mins or so may give u the answer, had that happen lots of times with win7
Samsung RV520... | Answered on Nov 23, 2013
Make sure you are not on caps lock. Also see if you need to have your number lock on or off.
Samsung RV520... | Answered on Oct 09, 2013
i would suspect the power pack has failed
Samsung RV520... | Answered on Aug 20, 2013
Has there been ANY damage? Spill? Try a System Restore to a date before this issue.
Samsung RV520... | Answered on Jul 18, 2013
Please provide me with the following information so that I can help you:
1. Operating System of your Computer
2. Specifications of your computer
David
Samsung RV520... | Answered on Jun 10, 2013
Go into the BIOS then to the Device boot order and make the CD drive the first boot device and the hard disk the second boot device.
Samsung RV520... | Answered on Apr 16, 2013
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
also b> http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted.
Samsung RV520... | Answered on Feb 18, 2013
go to the website to get the right driver
Samsung RV520... | Answered on Feb 09, 2013
Samsung RV520 Laptop Logo
Popular Tags
50 questions posted
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
samsung laptop left touchpad button
  • Computers & Internet
