20 Most Recent
SHARP MX-3100N Questions & Answers
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
What is the full meaning of ptc, mfp, scu, pwb,LSU,LCC,SRAM,SUM,CPT
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Will not print from Acer laptop
Is the copier locked, do you need to input a user code to use the copier?
If so, you need to enter that user number in the job handling tab of the printer preferences page.
