20 Most Recent
HEWLETT-PACKARD HP Pavilion G71150us Notebook Questions & Answers
Hp pavilion g71150us number keys do not work
It is time to replace your keyboard. It is dying. You can buy the replacement keyboard at eBay.com (use your laptop's model number to search the compatible keyboard). Later, you can download the laptop's service manual and read it, so you can replace the keyboard by yourself.
Change Processor
Thats the glu used for specific purpose, if you do not have proper idea than don't try it, you may damage the parts of the notepad, however a help video is here
http://www.youtube.com/watch?v=3ZxbPTWAJxU
Left speaker stoped working.
Ramon go to control panel, sound and check sttings.Are the speakers set as laptop etc. While there adjust your volume as well.
Hp g7-1150us will not power up
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
How do i restore my laptop?
Start > All Programs > Accessories > System Tools > System Restore.You can restore your laptop for a selected date. Computers automatically create restore points, and restore points are created when you download certain applications. So it may not go back to an exact date, but definitely for a specified month.BMW ACCESOSRIES
HP DV7-4065dx - Stuck in Hibernation...
I have the same model with the same problem, a friend of mine who is a technician removed the cooler and cleaned it, then with a hot air gun heated the video chip and the computer worked again
HP pavilion dv6000 turns off by itself
Sounds like a harware issue for sure, You know that you have one issue with the bad display. Since it stayed on while running disk check - which doesn't require much ni the way of graphics - it makes me think that the shutdown issue relates to the failing video interface. Some laptops will allow you to upgrade the video, but I don't honestly know if this is one of them. If so, this is where I would start looking.
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
