20 Most Recent
TDK Indi DVD 420N (AID+420N) DVD+RW Burner Questions & Answers
I can't seem to find
this is not a driver or a firmware problem. The issue is most likely a dirty laser lens, try a dvd lens cleaner disc, or you can try cleaning the lens yourself if your outside of warranty open up the drive, remove it from the computer, use a q-tip with 70% or higher alcohol. I've personally used just water on the q-tip - because I don't have the alcohol around.
wet the other end of the qtip with alcohol or water, clean the laser lens, then dry it with the other end of the qtip.
Here is a video on how to clean the laser lens, its for a PS2, but it does not matter as you would clean any lens like this.
Tdk dvd rw aid+420n
this is the 420N, not the 440N?
is this an internal or external burner?
what operating system are you using? on Windows XP, there's a good chance that you can just use the default drivers for that...
the best set of drivers i can find is here:
http://www.opendrivers.com/categorycompany/15/11603/cd-rom-tdk-free-driver-download.html
but most of those are firmware updates, or for slightly different models.
Computer is asking me to format my TDK usb drive
Please restart your computer once before attempting to access your external drive again. If this issue continues, please temporarily use another computer to access the drive and run a virus scan on your windows 7 computer. Thank you.
Can't get it to open
There is always a hole in the front of the tray. Just put a paper pin through it and press gently. It will release the tray lock manually.
Model DA-3826
electronic engineers/repairs will are the ones that would help to fix your player.
I would not know where you can find them because I am sure we don't stay in the same location.
I would advice that you search for local electronic repairer within your area or if you can locate the store of the maker/producer of your Player so that the repairs can be carried out.
Take care.
Tape life
it depends on which tapes are used.. it should be on the packing of the tapes themselves, it should tell you how many write cycles they are good for... just like video tapes and audio cassetes these tapes wear out in the same way.
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
