20 Most Recent
Cosco Juvenile Cosco Sway n Play Swing Zambia Questions & Answers
Trying to get the mobile
If you look there is a whole in the mobile that the screw driver will go in and take the screw out
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I
tools needed : 1 Phillips head screw driver, 4 d cell batteries.as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.it's the leg with the on off switch.insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door. unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.hope this helps!
I can't figure out how to switch from position 1 to position 2.
U have to grab the bar and like pull out and move it back and forth between positions. If your sitting in front of the swing(chid facing you) grab bar and pull away from you and move seat. Might have to hold the little side thing that says one and two to keep it still.
