20 Most Recent
Toshiba (SD-R2412) for Satellite A10, A15, A40, A45, Tecra A1 Series (SDR2412) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
I am trying to transfer
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rw/dvd-rom burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
1/16/2011 8:29:49 PM •
Toshiba...
Answered
on Jan 16, 2011
Cant read cd/dvd
The problem will be in a lens of the driver of your computer.
Try to clean by any lens cleaner cd and check it
If then also it is not working means contact service person and submit for repair
3/4/2010 4:07:04 AM •
Toshiba...
Answered
on Mar 04, 2010
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction.
Only TDK??? What about other media types?
Did you try a diffrent burning software?
6/18/2009 9:11:01 PM •
Toshiba...
Answered
on Jun 18, 2009
Dvd decoder
YOu need a 3rd pary dvd player software installed, Like power dvd. Power DVD , Win Dvd etx, you should have gotten a copy of a player when you brought your computer, If you didnt or cant find it you can download one, many have trial versions or you can get a free one.
If you get a trial version of Power Dvd it automatically installs a dvd decoder. even if power dvd trial expiers and you cant use it anymore you will still be able to play the dvd's on windows media player cause the decoder will remain there and media player will have axcess to it :)
6/9/2008 5:15:35 PM •
Toshiba...
Answered
on Jun 09, 2008
Insert disc code 011-02-1028
It may be compatibility issues with that certain blank dvd media, dvd drive may not have dvd writing capabilities or drive is faulty.
2/22/2008 10:55:55 AM •
Toshiba...
Answered
on Feb 22, 2008
Successfully burned yet can't play on stereo
Your stereo is a genuine detect sensor , only genuine product can play, The combo burner product are could pirated , so your stereo are having genuine detection it connot play.
1/3/2008 4:13:19 PM •
Toshiba...
Answered
on Jan 03, 2008
Dvd-ram
RUN a register cleaner or repair program
I use TUNE UP UTILITIES
Reinstall drivers
12/30/2007 5:53:31 AM •
Toshiba...
Answered
on Dec 30, 2007
Cd burner not working
I suspect you are doing nothing wrong... It sounds to me as if ya CD is gone faulty..
However download, install try Alcohol 120% & or Nero B4 ya buy a new one..
If after ya install and use those proggies it is still the same.. as I suspect, then as I said B4 .. ya gonna haveta get a new one sry.. :(
8/20/2007 3:22:49 AM •
Toshiba...
Answered
on Aug 20, 2007
Cd burner
1. go to device manager
/ right click on cd drive
/ uninstall driver
/ reboot and windows will reinstall driver
2. go to My computer
properties - check digital cd playback
recording - check enable cd recording on this drive
driver - update or uninstall
reboot your computer
3. go to support.toshiba.com
look for the EXACT model of your toshiba notebook
a) download latest BIOS
b) download the cd driver
2/1/2007 8:25:31 PM •
Toshiba...
Answered
on Feb 01, 2007
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
2 days ago
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
