20 Most Recent
Toshiba Portege 3505 Tablet PC Questions & Answers
Need to get into bios
Hit escape repeatedly while booting. When you get an error message that says hit F1 DO IT. Then you will enter bios.
I have a toshiba portege
That BIOS-password exists to protect you, should a thief gain posssession of your computer.
Find your original sales-receipt, to prove that you are the rightful owner, and telephone Toshiba.
Ask for Technical Support -- they can help you "nullify" that BIOS-password.
Portege 3505
pls get ur cdrom service & try again but prior to that pls check ur data cable which is connected to ur pc
Tablet PC "seeing" networks, but not connecting
The first thing I would do is install is a PCMCIA wireless card. If you are able to log in to your network with the PCMCIA wireless card, I would be leaning towards replacing your internal wireless card.
Hope that helps.....
Restore windows
There is no factory settings for windows.
You can restore the system to it`s old position from "system recovery"
How to use the pen
Using the pen is quite simple.
You extract it from its storage space and use it as a mouse, left clicking it as you would a mouse.
By pressing the tip of the pen on an area on desktop or on an application window and maintaining the pressure for a short while, you activate the context menus (the equivalent of a right click.)
On the Windows task bar (for Windows XP) there is a small icon near the start button that shows a pen pointing outside: that is the input panel. Click the icon with a mouse or your pen, and an input area opens. In that area you write with the pen (writing Pad) or enter letters and symbols one at a time (Character Pad) or use a virtual keyboard.
Under the red X that closes the input panel there is a small gear. C;ick the gear with the pen or a mouse to configure the settings.
Your pen may have an eraser at the rear end and/OR on the side. It is used to erase characters or whole sentences.
To actually record (write) what you enter with the pen you must have a text-editing application open and running.
Whenever you approach the pen to the screen near a text-area (search area of IE or other compatible applications) a small icon appears to be clicked to enter text. This happens is you select UNDOCK in the input panel configuration.
This should get you started with the pen. Try these steps, and if you have any other questions post them as comments to this thread and it will be my pleasure to answer them.
Blue screen
try to boot to windows xp or dos command, for winXP go to recovery console-select your windows-type the admin password then if C:\WINDOWS come up type chkdsk /r if that doesnt help, repair your operating system or backup your files and reinstall your operating system.
Quiero formatear mi laptop una toshiba portege
First , try letting "Windows Update" install new driver. Be sure to plug in any USB devices you want to use BEFORE you start Windows Update. That way ,Windows Update will detect these USB devices as well as your USB hub. Because it may be that your external USB device is the problem.
