20 Most Recent
Toshiba Tecra 8000 Notebook Questions & Answers
How to relace BIOS battery ?
Turn off and unplug pc, and then remove the bottom of the laptop until you see a 3VDC Round Silver Wafer battery inside a clip. Simply remove the battery from this clip and reinstall a new 3vdc battery. Notebook cmos batteries are harder to replace than Desktop pcs, so be careful.Watch out so you don't lose the TINY case screws.
How do I do a factory reset on my laptop?
Turn the computer off using the on/off button, then turn it on again while repeatedly tapping <F12> or <F1>. That should get you into OS setup. If that doesn't work, you will need a recovery disc or a new windows disc. Put the disc in the drive and start tapping <F12> or <F1>. The computer should give you the option to boot from CD.
Acer netbook d257 limited or no connectivity
If you get a 'Limited connectivity" on your wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router. To fix this problem, right click on the wireless icon on the Task bar and then click Repair. This will force the wireless router to issue a IP address to the wireless card on the laptop.
TOSHIBA PAT800U POWER UP WITH A BLACK SCREEN AND BLINKING CURSOR
3 Possible solutions.1. Remove any media and USB attached items.2. Reseat the hard drive if possible.3. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key (F1 or F2). Make internal hard drive first. Save and restart.Note - The hard drive must to be listed in BIOS, or there is no going forward.
How to access the bios of a toshiba tecra 8000
Turn the computer off completely, and then turn it back on.
Press and hold the "Esc" key on the keyboard immediately after turning the computer on. After a moment, the computer will prompt you to press the "F1" key to enter the motherboard BIOS configuration utility.
Press the "F1" key when you see the prompt. The BIOS configuration utility will load.
Forget pin cmos
You will need to remove the Cmos battery to reset this pin.
Be very sure you're confident in doing this, as it'll require disassembling the laptop.
Thanks.
Hello
i have problem met
To reset the BIOS password read the information from this
link.
In case of your laptop I would suggest using software from Hiren's Boot CD to reset the BIOS.
My toshiba tecra8000 laptop displays toshiba logo
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Toshiba Tecra 8000 Laptop has been stored for 1
Try accessing the BIOS screen when it boots up by pressing either the ESC or F1 keys repeatedly and there should be a password or supervisor password section where you can disable all the passwords.
