20 Most Recent
Toshiba Satellite Pro 4600 Notebook Questions & Answers
I turn on my computer but the screen is still black
think you might have a failed
screen inverter (FL inverter); this problem is very common with laptops. The inverter board acts as a power supply for the LCD screen backlight bulb, it converts low voltage DC power into high voltage AC. On most laptops the inverter board is located inside the display assembly below the LCD screen and you can get access to it if you remove the screen bezel (LCD mask). When the screen inverter goes bad the backlight will not turn on anymore or it turns on for a short time and then goes off, but you still can see a faint image on the screen and the external monitor works just fine. First of all I would make sure it’s not just a loose connection and reseat connectors on the inverter (it looks like you already done this part). Next, I would try replacing the inverter board. It might fix your problem with the backlight. It’s possible that you have a faulty cable, bad motherboard or even bad LCD screen, but I would try replacing the screen inverter first.
6/4/2013 9:24:04 PM •
Toshiba...
Answered
on Jun 04, 2013
The laptop will not come on?
Hi.
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for forty seconds.
Install either the battery or ac adapter power and press the power button toattempt a boot into the OS.
Hope this helps.
Shiboram
9/18/2011 3:58:26 PM •
Toshiba...
Answered
on Sep 18, 2011
How set bious
restart laptop then press delete 2 or 3 times.
bios page will open
if u need to set bios to install windows then change boot sequence.
8/31/2011 10:46:13 AM •
Toshiba...
Answered
on Aug 31, 2011
Hi there i have a
Your mouse pad/ touch pad will be
located under the keyboard on the front panel.
7/25/2011 2:25:50 AM •
Toshiba...
Answered
on Jul 25, 2011
Have lost password
Download the boot disk called Kon-Boot. You can reset your administrator password using this boot disk.
7/6/2011 9:32:16 PM •
Toshiba...
Answered
on Jul 06, 2011
When I first plugged it in the laptop was beeping
Hi
I know this may sound crazy but was the power cord switched on and did you check that the cord was not seperated where it joins
also can you get your hands on another power cord to try as yours may be faulty
12/8/2010 11:57:21 PM •
Toshiba...
Answered
on Dec 08, 2010
Hi i need to know how do i adjust the screen
Hi
somewhere on the laptop key board should be 2 keys with lights on them one for brighter and one for dimmer it you hold down the FN key as well as pressing the brightness key it should become brighter
hope this helps
11/18/2010 6:24:57 PM •
Toshiba...
Answered
on Nov 18, 2010
