20 Most Recent
Toshiba Tecra A2-S316 (0032017250819) PC Notebook Questions & Answers
I would lick ti instal
When booting you laptop notice the Toshiba scree. As that screen displays with the option F2 or F10. With your XP cd in the DVD/CD drive choose F10 and set your boot device to DVD/CD.
And follow the onscreen prompts.
Hope that helps.
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
My phone is not turning on
I have had this on an iphone 5. Apple sold me a new phone as it was not worth repairing and it was out of the 12 month warranty. Its possible to order a new part and do it yourself but unless you are totally confident and have the skills to open up your phone and reassemble it then its just not worth it.
Tecra s10 display brightness
look closely at the keys along the top of the keyboard (usually called F keys). one of them should have a tiny sun icon and the key beside it will have a larger sun icon. hold down the "Fn" key elsewhere on the keyboard while pressing the one of the sun icon keys to brighten or darken the picture. the sun icon keys may also be located on the Arrow keys (<-- --> etc.)
How to remove dvd drive
When does it open on its own?Sometimes it is easy to be press the open button as you close it which of course opens it straight away.It can also fail to lock closed if not opened further than its initial amount that it does open.To close it after it opens you need to draw it back to rearm the mechanism.
PCI Express Error
You might try taking the battery completely out for about 60 seconds, and see if this does not reset whatever got hosed. Also, unplug any external devices (like wireless keyboard/mouse, SD card reader, ...) that may be trying to use the PCI buss, just in case something is hosed with them.
How to troubleshoot a non display laptop?
if you can plug in an external monitor and it shows on the external display then either the laptop screen is damaged or you have switched the display to external as default. If nothing shows then it may be a motherboard problem.
