20 Most Recent
Toshiba Satellite 1135-S1553 Notebook Questions & Answers
My lcd is broken. I'm trying to connect it to
If you connect a monitor to the video port on your Toshiba, power up the monitor first and then boot up the Toshiba then the video will automatically divert to the monitor.
6/6/2011 5:36:15 AM •
Toshiba...
Answered
on Jun 06, 2011
Shuts off by itself
Check the fan to make sure it isn't clogged with dust bunnies or malfunctioning. There's a solid-state thermostat that turns off the computer if the processor overheats.
3/8/2011 5:12:58 AM •
Toshiba...
Answered
on Mar 08, 2011
Hello. I am having a problem loading windows. I
There is a way to correct this but not without a windows disc.You can contact your system manufacturer for a copy of the disc, but they will most likely charge you. Also you can borrow a disc from a friend so long as it is what you are licensed for ie Windows XP, Windows Vista, Windows 7 home or pro. Also you can torrent a disc but I cannot advise as to its legality.
2/28/2011 6:08:41 PM •
Toshiba...
Answered
on Feb 28, 2011
Where is the HDD located?
depends whether you have an old disk-type drive thats inside the machine.newer systems and future technology dictate SSD's these days(Solid state drives) They have no moving parts and are a series of chips,.processors and minature surface mount components non-user servicable but replaceable.
9/6/2010 9:52:34 PM •
Toshiba...
Answered
on Sep 06, 2010
Toshiba satellite 1135-S1553 randomly powers down
Hi
Thank you for your query
Please try the folowing
1) Switch on the Laptop
2) Press the F12, or del key to enter bios/setup
3) Leave it in this mode
4) If the laptop switches off, then your CPU is overheating and the heat sink will need to be replaced
Please book your laptop into a reputable PC shop for repair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
2/22/2010 7:10:45 PM •
Toshiba...
Answered
on Feb 22, 2010
Wireless
did you have it in the past? is your wireless adapter turned on? toshibas have a tiny switch someplace on the side of case. and the fn key combo also will turn off. make sure wireless light is on. if it is than card may be bad, if not than turn it on.
12/1/2009 8:56:25 PM •
Toshiba...
Answered
on Dec 01, 2009
Will not start up
Try removing the battery and replacing it. If that doesn't fix it hold down the power button and it should re boot. If still a problem we can go further.Thanks
3/2/2009 9:54:55 PM •
Toshiba...
Answered
on Mar 02, 2009
Wireless problem
Perhaps you have not installed ALL the drivers for your system.Sometimes a missing driver for other hardware causes a problem.After installing all the drivers for your system and if it still doesnt work , try using the connection manager built into windows (instead of configfree).
12/18/2008 7:35:47 AM •
Toshiba...
Answered
on Dec 18, 2008
