20 Most Recent KitchenAid Chefs Chopper KFC3100 3 Cups Food Processor Questions & Answers
2answers
My food processor blade keeps popping up (loose) when I put food into it.
You will probably need to replace the sleeve on the motor shaft and the blade. If overloaded the shaft can spin inside the blade which wrecks the connection between them. Replacing both together is the correct solution.
11/18/2019 6:12:55 AM • KitchenAid Chefs... • Answered on Nov 18, 2019
Kitchenaid kfc 3100
Probably the mechanisms in either the bowl or the parts of the lid that engage the bowl mechanisms.
12/21/2013 3:38:26 AM • KitchenAid Chefs... • Answered on Dec 21, 2013
Kitchenaid kneading blade stuck
Check that the safety lock pin is releasing from the base. It is the thing in the tube down the side of the bowl that the lug on the lid engages with. It stops the motor running with the lid off..https://www.google.com/search?q=Kitchen+Aid+food+processor+bowl+stuck..
8/4/2023 4:33:03 PM • KitchenAid Food... • Answered on Aug 04, 2023
2answers
Question about KitchenAid KFP0711 KFP0711OB 7-Cup Food Processor - I unscrewed the handle to clean it and the spring mechanism fell out. How does it go back together?
I have the 11 cup Kitchenaid food processor and did the same thing this weekend. It took a while but finally figured out how it went back together. Hopefully the pictures help. I know it's difficult to see since the pieces are all black. Good luck!
1/17/2023 9:19:26 PM • KitchenAid Food... • Answered on Jan 17, 2023
Blade in food processor stops turning under load.
Could be a failing motor
6/19/2021 3:15:46 PM • KitchenAid Food... • Answered on Jun 19, 2021
2answers
Lid is stuck in wrong direction will not come off
I got the lid off by using a turkey-skewer (i.e., a long pin) to push down on the long white plastic piece, in the handle, just above the spring. When you push it down far enough, you can twist the cover back over to the proper side. (We think we created this situation ourselves by mistakenly twisting the cover into place clockwise, rather than counter-clockwise.)
12/23/2020 4:26:42 PM • KitchenAid Food... • Answered on Dec 23, 2020
Kitchenaid food processor KFI 1325 brand new first use and won’t turn on
Make sure you have the bowl, lid and sometimes the pusher assembled correctly. If everything is not correct it will not activate the safety switch to allow it to start up.
2/28/2019 4:24:12 AM • KitchenAid Food... • Answered on Feb 28, 2019
Just purchased an kitchenaid with food processorattachment an it want work the processor what would i need todo to get it going?
take it back and get a warranty replacement unit reading the user manual may be a help
9/10/2018 3:27:40 AM • KitchenAid Food... • Answered on Sep 10, 2018
My Kitchenaid KFP6000B food processor still works fine, but it is becoming very difficult to lock the blender top in place in order to turn it on, and then difficult to remove the top.
Possibly something about either the lid or the bowl has become deformed. Very likely you will need to replace one or the other.
9/8/2018 4:53:22 AM • KitchenAid Food... • Answered on Sep 08, 2018
2answers
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
7/18/2018 10:00:03 PM • KitchenAid Food... • Answered on Jul 18, 2018
2answers
Kitchenaid food processor KFP1642MS This model requires the bowl, lid and plunger to be installed before it works. With all items installed this processor has been intermittent and getting worse.
The solution is 90% going to be replace the lid, or replace the bowl or if you are very unlucky replace both. A proper KitchenAid service agent should have both parts on the shelf and will be able to try a new one of either to see where the fault lies. I think over the years I've replaced more lids than I have bowls.
2/28/2018 11:34:03 PM • KitchenAid Food... • Answered on Feb 28, 2018
Drive shaft broken and melted
Find your model number on the list and look for parts Kitchenaid Food Processor Replacement Parts Accessories Sears PartsDirect
12/20/2017 1:46:35 AM • KitchenAid Food... • Answered on Dec 20, 2017
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
11/24/2017 11:42:28 PM • KitchenAid Food... • Answered on Nov 24, 2017
How to use the dough blade with my kitchenaid food processor
hi kimberly. not sure if this link will help you out but have a look. How to use the dough blade with my kitchenaid food processor Google Search
11/2/2017 4:17:59 PM • KitchenAid Food... • Answered on Nov 02, 2017
Recently moved to Australia. Is there anyway I can
Without step-down transformers you are out of luck. I am sorry. I know the transformers are ugly but they are cheaper than replacing your food processor and espresso machine. One thing you could do is to contact Kitchen Aid and ask them if the motor can be wired for 240V. If not, ask them if you can purchase the 240V motor for your processor and replace it directly. As for the espresso machine, no idea...sorry.
10/26/2017 8:19:14 PM • KitchenAid Food... • Answered on Oct 26, 2017
I have a kitchenaid foodprocessor
food processors have interlocks between the bowl, the top and the base. Inspect to see that those are all making. When you lock the bowl to the base and the top to the bowl you should hear some clicks and see some interlock mechanisms line up at the back of the bowl.
8/3/2017 3:39:41 AM • KitchenAid Food... • Answered on Aug 03, 2017
I turned the lid of my KitchenAid food processor too far. Is there any way to get it off? It is very tight. I haven't been able to turn it back or front.
I don't see anything other than hot water and brute force doing anything to help. Probably a two person job and make sure you turn it the right way. Be prepared for something to be broken or damaged.
7/2/2017 7:36:14 PM • KitchenAid Food... • Answered on Jul 02, 2017
Why is there no recipe book with my new kitchenaid food processor? Jemma
They now have moved over to an app for that
5/12/2017 6:57:34 AM • KitchenAid Food... • Answered on May 12, 2017
KitchenAid Chefs Chopper KFC3100 3 Cups Food Processor Logo
Popular Tags
4 questions posted
Top KitchenAid Food Processors Experts
NOEL
NOEL
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Processors
Most Popular Question
  • Food Processors
