20 Most Recent
Toshiba Tecra M4 Notebook Questions & Answers
Tecra M4 with blank screen or colors wrong (red instead of black)
THis happened to my Tecra M4 4 times in 4 years. Each time was a motherboard replacement at the tech repair shop. Each time cosint about $600. I have heard of the heating method to reflow the solder but don't know how to do it. Others have paid for the motherboard replacement and modded the GPU fan to constantly run. I may get it fixed once more and try using a laptop cooler to keep it from overheating again. Because it is soldered on to the motherboard, they replace the entire board.
There is no display but fan and diskdrive are
Attach an external monitor to your vga port and see if you can see anything if you can your screen is faulty and will need replaced. If it doesn't work on the external monitor your system board maybe faulty even with the fan and diskdrive working. If its under warranty get it fixed for free if not buy a cheap one online. Hope this helps
I recently installed a new hard drive on a toshiba
WHEN U RELOADED THE OPERATING SYSTEM HAVE ALL THE UPDATES BEEN INSTALLED? DO U HAVE A ANTI VIRUS PROGRAM, IF NOT GET ONE AND SCAN THE SYSTEM FOR ANY KIND OF INFECTION, THAT CAN CAUSE THIS AS WELL, BUT 1ST MAKE SURE YOU HAVE ALL THE UPDATES, YOU CAN ALSO EMAIL TECH SUPPORT FOR YOUR COMPUTER, IT IS FREE AND THEY GET BACK TO YOU REALLY FAST, THAT WOULD HAVE BEEN THE 1ST PLACE I CONTACTED IF THIS WAS MY COMPUTER, THEN IF THEY COULDN'T PROVIDE ANSWERS TRY ELSEWHERE.
Reset password toshiba tecra m4
Hi there, if it' a BIOS password (black screen and white writing) you have to remember it, otherwhise you have to bring it in for assistance. They have tools to reset the password.
I have a 3 year old Toshiba Tecra M4 Tablet
It would be oen of three things... in order of cost;
1. LCD Invertor has gone bad
2. SCREEN has gone bad
3. Motherboard has gone bad
In either of the three it would most likely take a toshiba tech to pinpoint exactly the problem and do the repair. Although if you are handy enough you can get the parts and repair it yourself.
Toshiba tecra m4 bios password
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it by pressing F12 and use BIOS / CMOS Tools from it.
Toshiba Tecra M4 Bios Password Reset
there are two way
open take cmos you will see one littile batry in you laptop when you open take that battery out for mint then put back in
secound way is
jummer setting
Tecra M4 display problems
Nope there is nothing you can do. A reddish cast to the screen is a common indication that the backlight that illuminates the screen is going south.
Toshiba laptop tecra M4 bios password
The password may be saved in flash memory that needs no battery to retain it.
There is surely a 'cheat' to reset the password but I suspect the method is not real public since it could be used to reset a stolen unit too.
You might check for a retail outlet that sells Toshiba and call them to see if they can do this for you.
Most service techs will want to see some proof of ownership before accepting it for resetting.
Toshiba Tecra R85. CMOS battery location on it please?
is that a typo OP< R850 is it?
use you tube, key word dismantle.
or replace motherboard.
see coin cell in the process.
found it for you and is special battery rechargable it is, no CR2032 sorry
R850 found it by pretending to buy the whole mobo.
see the red x, it is bundle of batteries
like this
using the wrong battery it will explode, the users guide said that . and will.
