20 Most Recent
Apple Ipad2 32GB Wifi Questions & Answers
How do I delete music from my ipad
Method 1. How to Delete Individual Songs from iPad
Step 1. Launch the Music app on your iPad.
Step 2. Tap "Songs" on the bottom to see all of the music on the device. Choose the individual track you want to delete and slide your finger to the left across the songs.
Step 3. Tap on the red "Delete" button to remove music from your iPad.
Get another two ways in this guide:
https://www.imobie.com/support/delete-music-from-ipad.htm
Ipad 2 will not charge after update! Help
You should try resetting it
Press and hold down the sleep/wake button at the top of you iPhone or iPad.
At the same time, press and hold down the Home button on the front of your iPhone or iPad.
Keep holding both buttons until the screen turns off and then turns back on again and displays the Apple logo.
FarmVille 2 will not load
You need to go to the App store and into the updates section. Where your app is listed either choose "install", "update" or "update all"
Find my ipad2 serial number
Go to settings then to general then select about and from here you can find your serial number. Hope this helps.
Ipad2 disabled lost passcoad
You have to restore your iPad to it's original factory settings. Do this by plugging it into the computer that you originally set up your iPad with. Then restore to original factory settings. This will erase all your data but at least you have an iPad.
Ipad recovery
When you've forgot the lock screen password of your iPad tablet, you get 6 tries of the password entering. After that, the only way you could do is restore you iPad to Factory Settings, which would then no doubt delete your data and files on iPad. The lost data and files would not be backed up on iTunes then. In such case, the only way you could recover data and files from locked iPad is to use 3rd-party data recovery software app.
Forgot iPad Screen Lock Password How to Recover Data from Locked iPad
