20 Most Recent
LG WM3360HVCA Washer Questions & Answers
Washer won't drain in spin cycle?
1) The drainage hose must not stay in a lower
position than the top of the machine.
2) The drainage hose must not be bent or
clogged in any way due to the surrounding
physical configuration.
3) Open the the drainage pump filter tray, it must not have any improper substance or material inside that may cause
a machine breakdown. Ensure that the pump impeller turns freely.
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
