20 Most Recent
Canon MF4570DN AllInOne Laser Printer Questions & Answers
I have a problem with my canon printer g3411. It has an error P03 but no paper jam. How do I solve my problem
Error P03 on a Canon printer typically indicates a paper jam, even if you cannot physically see any jammed paper. Here are a few steps you can try to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Carefully check the paper tray and inside the printer for any jammed paper or debris.
- Remove any jammed paper or debris you find.
- Plug the printer back in and turn it on.
- Attempt to print again.
If you don't see any paper jammed in the printer, there are a few other things you can try to resolve the error P03:
- Try resetting the printer. To do this, turn off the printer, unplug it from the power source, and wait for a few minutes before plugging it back in and turning it on.
- Check the ink cartridges and make sure they are properly seated and have enough ink.
- Clean the printer's rollers. Rollers are the small rubber wheels inside the printer that move the paper through the printer. Over time, dust, debris, or ink can build up on the rollers and cause paper jams. Cleaning the rollers can help resolve the issue.
- Try to update the firmware of the printer. Sometimes, a firmware update can resolve the issue.
- Check the printer's settings, ensure that the size of paper loaded match the size of paper set in the settings.
If the problem persists after trying these steps, you may want to contact Canon support for further assistance.
How to slove error e732-001 of canon ir 3225
The E732-001 error on a Canon iR 3225 indicates an issue with the fixing assembly temperature. Here are some steps to troubleshoot and resolve this error:
Reset the Condition:
Enter service mode by pressing the following sequence on the control panel: COPIER > FUNCTION > CLEAR > ERR.
This will reset the error condition. If the message disappears, your printer is ready to use. If this doesn't work, there may be a hardware problem as addressed below.
Replace the Main Thermistor:
The main thermistor is responsible for temperature sensing. If it's faulty, it can trigger the E732-001 error.
Consider replacing the main thermistor to resolve the issue.
Check the DC Controller PCB:
If the problem persists, inspect the DC controller PCB for any defects or malfunctions.
Replacing the DC controller PCB may be necessary.
Remember to turn off the printer before performing any maintenance tasks. If the error persists or if you need further assistance, I recommend contacting your local authorized Canon dealer or the Canon Customer Support Center for professional service
How to fix a problem with the laser unit
Fixing a problem with a laser unit depends on the specific issue you're facing. Here are general steps you can consider:1. **Inspect and Clean:** Examine the laser unit for any visible dust, debris, or obstructions. Use a can of compressed air to gently blow away any particles that might affect the laser's performance.2. **Check Connections:** Ensure all cables and connections related to the laser unit are secure. Loose connections can lead to malfunctions.3. **Calibration:** Some laser units may require calibration. Consult the device manual for instructions on how to perform calibration procedures. This often involves using specific calibration tools or software.4. **Replace Toner or Cartridge:** If print quality is an issue, consider replacing the toner cartridge. Low toner levels can affect the laser unit's performance.5. **Firmware Update:** Check if there are firmware updates available for the laser unit. Manufacturers may release updates to address performance issues or bugs.6. **Professional Service:**https://capcuttemp.net/rara-capcut-template/
I have a Canon MG7766 printer with error code B203. I noticed when I open the cover that the ink tank carriage is parked at the left side.
Canon Printer Error Code B203 Solution - ijstartcanon.ca
ijstartcanon.ca
https://ijstartcanon.ca > canon-printer-error-code-b203-...
Like many printer errors, this issue is related to a jam, but it is unlikely to be a paper jam. We have received data both offline and online, and many people ...
Missing: MG7766 ' Show results with:
MG7766
Solved: Canon Pixma MG7750 Showing Error Code B203
Canon Community
https://community.usa.canon.com > Canon-Pixma-MG7...
Apr 27, 2022 - I searched around and see other have suffered this fate, does anyone know what this error means and why the printer is failing, its hardly had any use, new ...
MG7720: Error B203 Suddenly occurs, on MULTIPLE pr...
Apr 27, 2021
PIXMA MG7720 Support Codes 1403 and B203
Mar 14, 2023
MG6821 Error Code B203 - Canon Community
Sep 3, 2020
PIXMA MG6620 Support Code B203 - Canon Community
Dec 12, 2023
More results from community.usa.canon.com
Canon imageRUNNER ADVANCE C2230i. How to fix error E000355-0004 please?
Question edited for clarity.
I hope you didn't pay $5 to get an answer as suggested by Jaramie Kinsey?
Canon imageRUNNER 1750, 1740, 1730 Error Code E355 ...
Error Codes > Canon > iR Advance 4225 > Code E355-0004
Printcopy.info
https://printcopy.info > brand=Canon
Canon iR Advance 4225 ; Code: E355-0004 ; Description: System error ; Remedy: Contact to the sales companies.
Missing: C2230i ' Show results with: C2230i
E355-0004-00 System Error; E400-0001-04 ...
ManualsLib
https://www.manualslib.com > ... > Service manual
A communication error between the Main Controller PCB and the DADF Driver PCB was detected. ... [Remedy] Check/replace the related harness/cable, connector and ...
Copytechnet
https://www.copytechnet.com > ... > Canon
Feb 14, 2014 - This is retained in SRAM on the Main Controller PCB and held active by means of an on board battery. ... Mismatch of serial numbers of three items ...
IR1133 showing E355-0004 - Copytechnet
Aug 27, 2013
Error Code E355 on IR ADV 6075 & 8085 PRO - Canon
Jul 11, 2019
Error Code IRA 8105 E355-004 - Copytechnet
Mar 24, 2014
Canon iR ADVC5255 - Error E000355-0003 - Copytechnet
May 27, 2017
More results from www.copytechnet.com
C2230i
Error Code error code E355 - 0004 [Archive]
Copytechnet
http://www.copytechnet.com > archive > index.php
Feb 14, 2014 - 1) Enter the setting value under LOCALE, and then press OK key. 2) Set the paper size configuration under SIZE-LC. 3) Execute COPIER> FUNCTION> .
