20 Most Recent
Bushnell Falcon 13-3450 (10x50) Binocular Questions & Answers
We gave our son a pair of Bushnell Binoculars, and
The binoculars need collimation. The two sides are supposed to be parallel, if they are not you see two heads on horses, two footballs, two baseball bats etc. Check the binoculars for any external signs of damage. Are the front housings sitting properly in the body, is one of them not straight? If there is no obvious signs then you will need to take them to someone who can rebuild them for you. Usually the place where you bought them should be able to help you with a repair centre.
Eyepiece assembly bushnell telescope
You never told us what model number or telescope TYPE you own. Is this a refractor or a reflector. ???
If a REFRACTOR usually you have a diagonal, the diagonal goes into the focuser and then the eyepiece goes into the diagonal.
On a REFLECTOR the eyepiece goes directly into the focuser.
Bushnell Tour v3 laser rangefinder will not display yardage
Please shutdown your device for 5 minutes, booot up and then check for yardage again. If this does not work, then you might look into the device manual (in troubleshooting) to check for an alternative approach to fixing this. Thank you.
