20 Most Recent
LG GSA 4163B DVD±RW Dual Layer Burner Questions & Answers
The device does not appear
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this does not fix the problemyou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Hello.I am having problems with
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question or exclamation mark ? ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
http://www.opendrivers.com/companydriver/2165/optiarc-free-driver-download.html
you will need to select your operating system
also you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
So wat can i do
you have not said what the problem is so ill take a guess
a motherboard disc the drivers could be on it
make sure that the cd rw is
getting enough power test all leads that are attached to the cd rw including
electrical extensions and make sure they have a secure connection or just
replace them there might be bad/faulty
or
your drivers may have been
corrupted or you might have a virus run your antivrus program
you might have to
physically unplug the leads for this cd/dvd then plug them back in or
device
administrive tools,computer management,device manager scroll down cd dvd rom
drives right click you can you can update driver,roll back driver,or
Close all open
programs
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
hope this helps
Hl-dt-st dvdram gsa-t40n ata device driver curupted
Problem occurs when vista registry entry is corrupted. The steps to resolve this are as follows:
- run regedit.exe
- navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- Depending on your particular setup, you may have multiple entries for {4D36E965-E325-11CE-BFC1-08002BE10318}. If this is the case, find the one that says DVD/CD-ROM drives (under default)
- Once you have found the appropriate key, you will see an entry that says UpperFilters.
- Delete this key and then restart
- (NB: Do not delete any other 'UpperFilters' key that is not in the category of DVD/CD-ROM drives, otherwise you may get the BSOD.)
This solution fixed my problem.
My dvd rw not showing
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters Upper Filters.bak
Lower Filters.bak
hope this helps
Dear Experts,
I have connected an
OKay
Sounds to me your trying to do what i did and did not work. the issue is the netbook is not compatable with this method you need a netbook compatable External unit is what i suggest, if there are any experts that have diffrent advice I welcome it as well. But I tryed what your doing in fact i went out and bought a external unit because of this fact, the issue is compatability.
Thanks Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
