20 Most Recent
Philips Avent 630 SCF30201 ISIS Single Electronic Breast Pump Questions & Answers
Hi, I have a Philips SCD361 Monitor. Generally
The issue you are having could be caused by a number of things but the most likely is either interference from a transmitter in the same frequency range or the Monitor has a failing capacitor on the board.
If you can think back to when the issue first started and check to see if you have any new devices that might be on the same frequency range and test them by turning them off for a while to see if it continues though this would not be effective if you live close to anyone else.
If that does not work then use high quality batteries and make sure the unit is placed far away from any windows in the room also make sure any florescent lights are not in use near the unit and make sure its not next to any thing else that uses a power supply that has the square box on the plug that includes using the same outlet.
This particular device use's a low frequency range around 40mhz which can be prone to interference more then a lot of the newer units that use 800mhz to 2Gighz.
If all of the above fails you will have to replace the unit or seek repair from the manufacturer if it's still under any warranty.
Hello my name is miki and I want to buy baby
Yes! baby monitor is safe for your baby. I bought baby monitor for my 10 month old baby from http://www.hushbabies.com . This helps us to know when how long he has been awake and when to put him back
down for his next sleep.
Baby Care
My philips avent 1q24 electronic steam wont come on
Most likly a bad capacittor on the little circuit board inside the unit. As it is thermosealed you cant open it without voiding the warranty. The repair however is fairly simple and anyone with rudamentary electronics experience can fix it for you. If you are still having problems let me know on
[email protected]
My Pal Scout needs replacement battery spring..
I would perform a test use of the spring before purchasing it to reach this conclusion. You can call ahead to several part stores that you've identified to carry the spring and request if test use is possible. Then, work with the stores that say "yes". Thank you.
9/30/2022 5:41:42 PM •
Baby Care
Answered
on Sep 30, 2022
Tomy baby monitor srv 400 instruction
Hi
I have Tomy srv 400 but the parent unit is not working. I have attached a photo to show what its giving me when plugged.
If anyone knows how to fix it.
Thank you
4/1/2019 11:49:08 PM •
Baby Care
Answered
on Apr 01, 2019
I feel REALLY down, I Am Never Going To Get A Baby Girl?
Other
people would say, it does not matter what gender your baby will be and
that is a natural reaction but to some, this is a serious concern. Stop
worrying, Gender Selection Clinic
is the solution to your problem if you are really serious about it.
Technology and science have made it possible for people to get pregnant
and to choose the gender of their kids. The embryo gender selection IVF
is being performed by medical doctors around the world. This system has
been proven for decades. The success rate of having a girl is 93%. This
method though is a bit expensive but if you really want it, then the
cost would not be a problem to you. Both you and your husband must have
an open mind on this. Otherwise, it will create misunderstanding between
the two of you.
8/15/2018 7:03:40 AM •
Baby Care
Answered
on Aug 15, 2018
Is it dangerous to wear the wrong size of nursing bras?
Usually a woman's breasts engorge very quickly after giving birth and take a few weeks to gain a stable size, usually one size bigger than what she had before giving birth.Because of the quick and unpredictable extent of ****** growth some women end up wearing the wrong bra size, and while wearing a bigger size may just turn out to be uncomfortable, wearing a smaller bra size while breastfeeding may reduce their milk supply and cause a painful infections called mastitis.
4/3/2018 2:57:56 AM •
Baby Care
Answered
on Apr 03, 2018
How do they work
The basic loop is simple:
Feed
Burp
Change diaper
Get to sleep
Repeat
Then you need to work in a "change clothes" subroutine, which runs once/day, or when the outfit is filthy.
But while that loop is running, you need to frequently:
Maintain eye contact
Smile
Talk (content not important; babies hear high pitches better)
Play (Peek-a-boo works with a wide range of ages, but basically any repetitive action delivered with a smile will amuse a baby)
And snuggling. Lots and lots of snuggling.
10/22/2017 2:46:29 PM •
Baby Care
Answered
on Oct 22, 2017
