20 Most Recent frigidaire.com Questions & Answers
first, find a manual or contact tech support to determine what an e20 means. it could be a clogged drain.
frigidaire.com | Answered on Jun 05, 2014
more spam from larry and his partners
Computers &... | Answered 15 hours ago
A little more information will be required for the supplier. What is it, when was it ordered etc.
Computers &... | Answered Yesterday
Change Aspect Ratio in settings on your mystery device.
Steps To Fix Gmail Error Code 6922
  1. 1. About us ? Gmail is a famous email service which we use on a daily basis for sending emails, getting promotional messages of certain products, receiving the email recovery option, and lots more. It gives a tough competition to its competitors on the basis of amazing aspects of it. People have high expectation on it because of the reputation it has earned so far from working on the default settings to provide complete security to the emails, fast and intuitive designs. For more queries on Gmail, you need to contact Gmail Customer Service phone number to talk to the executives for the same.
  2. 2. Gmail common problems ? There are many times when people setback with specific problems while using Gmail. Some of the common problems are can't sign-in to Gmail, can't send or receive the messages, can't able to change the Gmail authentication number, can't attach large files, other numerical codes and lots more. To resolve the mentioned issues, you need to look for the proper procedure for the same.
  3. 3. What is Gmail error code 6922? ? This particular error code appears on the screen when the user tries to open the attachment in their Gmail Account. Or, the particular file or document is restricted to downloading. There may be the possibility that the attached file or the links are blocked or the Gmail message is suspicious.
  4. 4. The possible reasons behind Gmail error 6922 ? Outdated web browsers ? The network connection is poor ? The install security software has blocked the email as they found it suspicious ? The caches or the cookies are present in the browser ? The corrupted browser extensions
  5. 5. Quick fix Gmail error code 6922 ? You need to update your current Web browser properly. ? Check on the network connection whether it's working properly or not. ? Make sure you check on the settings of the installed security software. ? You need to remove all the caches and cookies of the browsers. ? You need to disable the browser's extensions temporarily.
  6. 6. How to contact Gmail Technical Support phone number? ? We hope that the given solutions have helped in sorting out the problem you were going through for so long. In case, you are unable to solve the issues completely, or you need more help for the other technical problems which you encounter while applying these steps, then you need to contact the technical specialists by calling on the Gmail technical support phone number.
Open an email account somewhere else (ex., Yahoo, Juno, NetZero), and then you can use that new email address to reset your password on Gmail. Good luck.
Unless you post what the supposed scam is and your country of residence how will anyone know which number you need if any
bos tlng saya lupa id ma pasword bola88
Computers &... | Answered 2 days ago
As you don't mention what advice you've followed, it's rather difficult to come up with new advice ....
But first (and this may or may not have anything to do with your problem) :
Your system details show that your Adobe Flash needs to be updated - you're running a very old version, which can cause problems.
Would you please uninstall your current version and install the latest version, which is 32.0.0.192
Uninstaller : https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
https://get.adobe.com/flashplayer/
Note : some 'extras' may be offered in the download.
Would you try this please :
Reload the page : Hold down the Shift key and left-click the Reload button or press 'Ctrl + F5' or press 'Ctrl + Shift + R'
Clear the Firefox cache :
https://support.mozilla.org/en-US/kb/how-clear-firefox-cache
"Remove the cookies" from websites that cause problems :
https://support.mozilla.org/en-US/kb/delete-cookies-remove-info-websites-stored (scroll down to : "Delete cookies for a single site")
If none of the above do the trick, then let's Try Firefox in Safe Mode :
If Firefox is not running : Hold down the Shift key when starting Firefox.
If Firefox is running : 3-bar menu => ' ? ' (at the bottom of the dropdown) => 'Restart with Add-ons disabled'. Then OK the restart. A small dialog should appear. Click 'Start in Safe Mode' ( not 'Refresh' !)
See : https://support.mozilla.org/en-US/kb/troubleshoot-firefox-issues-using-safe-mode
And : https://support.mozilla.org/en-US/kb/troubleshoot-extensions-themes-to-fix-problems
How to adjust the volume on the iPad and iPhone app.
  • 2 days ago
  • Updated
The steps below outline a few ways to adjust the alert/ alarm volume on your iOS app. If you're not hearing an audible alarm at all when timing is complete, please check out this guide to enable the alert.
In-App Time Alert settings
In the main Timer view (home view) you will see a green bell or vibrate icon under the Timer in the right corner. Tap on that to open two sliders for sound and vibration. When they are green, sound is ON. Tap the carrot (downward arrow) to hide the buttons.
Using the Volume Buttons or Sound Settings
The physical buttons on the side of your device are your main volume buttons: turn up the volume using the top button, and turn the down the volume using the bottom button. If this does not change the volume, navigate to Settings > Sounds and slide the Ringer and Alerts slider at the top of the page. You may also want to enable the "Change with Buttons" option to allow you to change the volume via the buttons on the side of your device.
If you've already set up that email account, you can still enable this option from within the settings of that account (you won't bring back email you've already lost, however). To do this, follow these steps:
  1. Open up the Email app
  2. Tap the menu button, and click Settings
  3. Tap Account settings
  4. Tap the account you want to configure
  5. Tap More Settings
  6. Tap Incoming settings
  7. Scroll to the bottom and look for Delete email from server
  8. Tap the drop-down and select When I delete from Inbox (the same way you would if you were initially setting up the account)
Reasons which results wrong transactions:
·Due to human (typing a wrong account number) or technical errors
·Human errors due to discrepancies in the account number, IFSC code or both
·Technical glitches at the bank's end can also cause the error
Time for quick action:
·Try to inform the bank and bank manager immediately after the wrong transaction
·Money will get back to your account automatically, if the account number you mentioned does not exists but in case the situation is opposite, you have to take immediate action
·You have to prove the bank in details that you transferred the money to a wrong beneficiary's account
·If the money is credited to the account of an unintended beneficiary with the same name as your intended beneficiary, then in that case you have to prove that the transfer itself was wrong before the bank can help. But it's not that easy
·Try to mail the matter in detail to the bank for the sake of better communication
·Bank can only act as a facilitator by providing you the contact number/branch name of the unintended beneficiary
·Try to follow up the situation regularly because at the end it's your hard-earned money
·In case the transfer intra-bank, the bank may approach the recipient on your behalf and request a reversal of transaction. If the beneficiary agrees, the transaction will be reversed within one working week
·If the beneficiary is of other bank and you transferred amount by mistake, then you have to go personally to that particular branch and meet the bank manager to get the solution done.
What if the wrong beneficiary refuses to give the money back?
·You cannot take the money back without the wrong beneficiary's consent. The beneficiary has to accept that the wrong transaction is made but it's not that easy
· In that case, contact your bank and update the matter clearly
·To keep a record of your complain; always try to mail the matter in details for better communication
·If he or she refuses to give your money back then you can do a legal case as well but the situation becomes more complicated if your bank and your beneficiary's banks are different, and/or are in different cities
·Taking legal route is time consuming which involves too many formalities which includes lawyer's fees etc
·If a beneficiary is okay giving your money back then it takes 8-10 working days to get your money back. Otherwise, you have to prove the transaction with the help of right statement, address and ID proof etc.
·No recovery is possible is the beneficiary contests the reversal and refuses approval
Rules to follow:
·According to the RBI guidelines, it is the responsibility of the depositor to provide the correct account number and IFSC code
·There is no rule that the banks will verify all the details
·Before transferring the money, always check twice or thrice the account number and the IFSC code
·It is always advisable to transfer a small amount of money. Like Rs.100, as a test to verify that the amount is transferred to the right beneficiary
·Try to double check the digits after typing and for online payment test transfer is the safest mode
·Try to complain immediately to the concern bank for wrong transaction and reply the bank as quick as possible. At the end it's your hard-earned money, so be cautious when you transfer the money.
sorry no clue here
frigidaire.com Logo
10 questions posted
Popular Products
Top frigidaire.com Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a frigidaire.com Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • frigidaire.com Computers & Internet
Most Popular Question
tumble action washer keeps giveing me
  • Computers & Internet
