20 Most Recent
SmartDisk USB Floppy Drive Titanium Edition (FDUSB-TM2) External Floppy Drive Questions & Answers
I am using a Mac
Windows XP "natively" supports this "plug-and-play" USB device.
So, if it is "dead", search eBay for "external USB floppy" and buy a replacement.
NewerTechnology uDriveSmartDisk USB Floppy Drive (model FDUSB-M, Color Kit Edition, formerly VST)
Verbatim continues to offer support on select SmartDisk products: CrossFire USB & FireWire Desktop Hard DrivesSOHO NAS Desktop Hard DrivesFireLite USB & FireWire Portable Hard DrivesFireLite XPress Portable Hard DrivePhotoBankUSB External Floppy DriveSelect models of CameraMate Card Readers For online support click here:
http://www.verbatim.com/contact-login.cfm or call technical support at 646-537-3411, Monday-Friday, 8 a.m. to 9 p.m. Eastern Time. Verbatim Acquires SmartDisk External Hard Disk Drive Business ----------------------------- Verbatim Acquires SmartDisk External Hard Disk Drive TOKYO, (July 5, 2007) - Verbatim® Corporation and its parent company Mitsubishi Kagaku Media (MKM), announced today the purchase of substantially all of the assets of SmartDisk® Corporation\'s external hard drive (HD) and digital imaging business. The acquisition, which includes physical assets, patents, trademarks, technology, engineering and marketing expertise, was effective on June 30, 2007.
Floppy drive
It came with a warranty? Correct ???
Exchange it for a non-defective unit.
When I plugged in the
Have not been able to find any drivers for this device for Win7-64, I works fine on pre win7 machines, but under win7 it says that all of my disks need to be formated.
When i try to
It is possible that there are errors on the floppy disk or the disk was formated using a format that is incompatible with the current operating system. If the disk is readable on another system, the best solution would be to copy the files onto a portable USB flash drive, then reformat the floppy disk using a filesystem that is readable on the desired computer.
I have a SmartDisk External USB 3.5" 1.44MB Floppy
well you I&hash39; have got problems the first thing i would be looking for would be a bad driver to this device
if you are having trouble
with your drivers
here is a general look at
the drivers and how to update them
if your computer came with
a motherboard disc the drivers could be on it
click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver if the problem still persists check the leads that attach to this device make sure they have secure seatings or just replace them they could be faulty from overstreching hope this helps
CANNOT FIND DRIVERS
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps don
How does it work?
Hi.
The external floppy reader is easy to use.
The unit is completely plug and play.
Simply plug the USB connector from the Floppy into the computer, the unit will be detected and installed automatically on any Windows XP, Vista, or Win 7 computer.
Installing the external drive takes no more than two minutes, usually less.
Once installed the floppy will be displayed into My computer, along with the other drives, exactly as if it was an internal drive, and it will be ready to use.
Let me know if you need further instructions.
Please do not forget to leave feedback.
Thanks.
Floppy
I'm assuming this is on a PC. If so, inserting a floppy will not cause the PC to do anything. (The reasons for this are historical and not important to solving your problem.) You need to open "My Computer", then browse to your A: drive to see the files on the floppy.
A handy shortcut to My Computer is to press Windows+E. (Like Ctrl+E, but using the key with the Windows logo on it instead of the Ctrl key.)
No power
Well, the first step in any problem of this nature is to narrow down the problem. We have three main things in effect here, and we need to know which one has the problem before we can fix it.
First, the disk itself. Try other disks and make sure the disk is not faulty.
Second, the usb ports. Try other devices in your usb ports to ensure they are installed and configured properly.
If all of those work, it is narrowed down to the floppy drive itself. If it does not work on any pc's at all, then it definately has a problem, and I would suggest contacting SmartDisk technical support.
I plugged in and powered on the SmartDisk CrossFire XF160 to my windows 8.1 pc, it automatically installed driver, but the drive does not appear in windows explorer. what can i do?
NO story told , first time used, this??? just bought it?
is it new or used,? IDK any of that, and data matters.
Ill assUme it is new with no precious data....
no PC stated, , w8.1 why not upgrade for free to w10?
smart disk or any external HDD, or SSD, all need to be formatted
first. you did only the last step. (first)
#1 plug in the USB cable to a working USB port.
2: go to CP control panel then admin tools then computer management and last disk management or.
2b: in the run box type
diskmgmt.msc
3: now diskmanagment is OPEN.
4: the drive shows up as a DISK NUMBER. only
5: right click your DISK seen in the list, do not pick Disk 0
6: make sure the DISK U picked size matches your external disk size.~~
7: right click the DISK1 or what it is and pick new simple volume
8: right click disk1 and format it. to fat 32 or NTFS.
9: assign a drive letter to the new drive, (from now on the drive external shows up in windows explorer as drive letter same.
that is it, same story on new empty USB thumb drive !
12/19/2019 1:40:12 PM •
SmartDisk...
Answered
on Dec 19, 2019
