It is obvious your scratch disk does not have enough space. I would say that truth about the memory problem is the Very Critical Memory Bug that comes with CS4. You can try to disable all the apps that are running at the same time, but the problem can be still here. Installing of a current AI version might help. Also try to save a TIF of the image in Photoshop, it could be a quick fix to the problem. Or reduced the pixels number.
If nothing helps, use a special software that is able to recover it. There are a lot of on network, but unfortunately not all of them are so good. Try Recovery Toolbox for Illustrator https://illustrator.recoverytoolbox.com/
Oh, also i've remembered one method: Unlock all the layers and 'select all' and 'copy'. Than create a new doc and paste your image in there. Save the document with a new name.
am pascal Mbarubukeye as seen on my profile, i would like to ask for supporting me to offer serisl number of adobe audition 1.5, because what i have was corrupted. please help me i begg!
Adobe Communityhttps://community.adobe.com > ... > Discussions
Dec 7, 2018 - Solved: I've had to reinstall all applications after restoring Win10, and I have my CS2 Standard disks; installation itself went fine.
11 answers · Top answer: See here and use the new serial number you will be provided : Download Adobe Acrobat 7 and ...
You should never post such codes on an open forum, others may use it against your wishes. If you call Adobe, they will straighten out the issue for you if your codes are legitimately paid for.
To help you out. Get yourself a little note book and write all pass words and codes and your computer information down in it and keep the note book in a drawer where you know where it is kept. When you change any information cross it out of your note book and put your new one in.Saves a lot of headaches when trying to remember .
Contact with Adobe will do you no good. The activation servers for this product are shut down. Even if you had the serial for it, it will not activate. Adobe stopped selling this in 2008. If you acquired it, you have an unlicensed product with no access to an activation server. I cannot supply guidance to any workaround if I found such as Fixya does not offer "cracking" services.
My serial number: 1045-1090-6246-8353-3166-2968activation number:5161-9399-8946-3178-9348-6374-4063activation type: Normal: 194:13my e-mail : [email protected] plz give me Authorization code
plz help me serial number-1330-1564-0603-9333-0603-5060
activation number-4309-6265-2467-6843-4212-7398-4895
plz snt me authorization code snd me [email protected]
