20 Most Recent
Casio Sea Pathfinder Sports Watch (SPF-60D-7AVDR)- SimplyRun Watch for Men Questions & Answers
Hello sir
i have a
I suspect there is water leaking in to the sensor unit circuit located just behind the sensor. The Casio service would change the sensor, and all the gaskets in the watch. Then do a water pressure test on the case and etc. to make sure no leaks. I do not think you can service this yourself. You would have to know exactly the parts to buy and have the tools, and the pressure chamber to verify the gasket seal performance.
You should send it to Casio with a copy of your complaint. Look up Casio on the Internet and choose your country. Go to support to find the service address and instructions of where to send the watch. If you email them it can take a few days till they respond. They will send you the specific instructions. Their service is terrific. I own a number of their high end watches. In fact I have one with them being serviced. Sometimes I have broken the glass because I am rough with my watches at times.
2/11/2018 7:26:39 PM •
Casio Sea...
Answered
on Feb 11, 2018
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
