20 Most Recent
HEWLETT-PACKARD G62-347NR Laptop Questions & Answers
HOW TO GET OUT OF SAFE MODE
1.Restart your computer. 2.Click on Start.3.Type msconfig in the search box and click enter.4.On the System Configuration windows, select the Boot tab.5.Under Boot options, uncheck Safe boot.6.Click Apply and OK.7.Restart your computerIf you need any kind of technical assistance ,you can contact support cell at
http://www.vtechsquad.com/
Hp g62 overheating
A good clean of the intake and exhaust vents is a good place to start.Next up is to ensure that your notebook is raised off of the work surface (table) to allow greater airflow through the notebook to cool it's components.Use a pencil or eraser, some-thing that will lift the notebook and not restrict airflow.Another solution is to purchase a notebook cooler, some units have a built-in fan which will help a lot.Take care!damnor01
Thids is not
Hello.
What seems to be the problem? Make sure the battery is inserted and try connecting the AC adapter too. Do you get an error code? Does it even power? Have you tried starting it on safe-mode?
How to change lock code
I'm assuming you mean the bios password. Turn off the computer. Remove the power supply. Remove the battery. Remove the CMOS battery. Hold the power button for 10 sec to drain residual charge. Plug the computer in and boot. The password should be disabled.
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
