20 Most Recent
Panasonic DVD-LA95 Portable DVD Player Questions & Answers
I have just bought a Panasonic DVD-LA95 but did
you need to check that it supports pal output, if its a european unit
(check the manual and player bottom for the ce mark) then it will play pal discs and will need reverting to the multiregion upgrade ( a disc and a few button presses about £20 online)) if its an american unit then it wont play pal discs even if you do manage to multiregion it.
11/14/2019 3:45:25 AM •
Panasonic...
Answered
on Nov 14, 2019
Panasonic LA95 Portable DVD
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
2/7/2010 9:59:09 PM •
Panasonic...
Answered
on Feb 07, 2010
Flashing red light Panasonic portable DVD-LA95
check the microswith near the hinge .
its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle.
this happened tome and i was on the verge of binning it. when i looked at the manual and it says
power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at
[email protected]
good luck
choonzy
2/7/2010 9:18:07 PM •
Panasonic...
Answered
on Feb 07, 2010
Portable DVD player won't read discs.
There are 2 errors, ho3 and ho2, I can't remember which one is which. One means the laser is going and one means it's a dirty track. I suggest you first very gently clean the lens. If that doesn't work you take apart the player and clean the whole track that the laser moves on along with everything around it (keeping in mind that the laser is fragile). If that doesn't work than I can't help anymore without seeing it.
6/13/2009 5:55:06 PM •
Panasonic...
Answered
on Jun 13, 2009
REGIONAL ERROR
You can make it regioncode freefollowing these steps..
1. Press "Setup" and go to "PREFERENCES" (DVD stopped and player opened)
2. Scroll to "PBC" using the LEFT/RIGHT arrow key
3. Press "138931" and a pop-up screen will appear.
4. Use the UP/DOWN arrow key to choose the desired number. ( 0 for regionfree!!)
Jay
5/20/2009 6:15:45 PM •
Panasonic...
Answered
on May 20, 2009
Screen very dark
hi sir
you got a burnt fluriecent or a deffect transistor driver to it
refer to qualified person to re change , but this is the fault sharply cost i2 20$
please don't forget to do excelent rate cause i here to help you
regards
12/4/2008 7:45:13 PM •
Panasonic...
Answered
on Dec 04, 2008
Panasonic LA95
You bought it on Ebay ! ! Why did the seller move it on...
I suspect that the decoder is getting 'hot' - same principle as the processor on your PC.
If you are able - I would suggest opeing the unit up (so that the main board is visible) but still able to power up.
Obtain a hair dryer that has a 'cool' blow on it. Start your unit up, while blowing with cool air - this will identify if this is thermal related...
8/15/2008 2:06:12 PM •
Panasonic...
Answered
on Aug 15, 2008
DVD player just shuts off when using
As you say - - if it does not happen all the time, you have the worst problem ever.
AN INTERMITTENT FAULT - Horrid
You are likely to be correct, and have a loose connection / poor solder joint / dry joint within the unit.
Time and patience could find this fault - as long as you have a soldering iron, and a good avo..
8/15/2008 2:02:53 PM •
Panasonic...
Answered
on Aug 15, 2008
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
8/15/2008 1:59:50 PM •
Panasonic...
Answered
on Aug 15, 2008
PANASONIC PORTABLE DVD PLAYER ERROR CODE 3. MODEL NUMBER LS5
This could be the laser going or a dirty track. I suggest that you first clean the laser gently. If this doesn't work you must take the player apart and clean the track that the laser moves on along with everything around it (keeping in mind that the laser is fragile).
4/1/2008 1:35:20 AM •
Panasonic...
Answered
on Apr 01, 2008
Getting sound from speakers when heaphones are plugged in.
Hi,I know that the earphone jack usually has the switch built in, and often it takes a certain "End Shape" on the Headphone Plug to actually "Activate" it... I am wondering if this is not actually your problem? and maybe ya just gotta get the "Right One"?
Sometimes I have seen the "Switch" in the Jack fail and cease to "Cut out" the speakers... which generally means replacement.
8/31/2007 1:19:45 PM •
Panasonic...
Answered
on Aug 31, 2007
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
