20 Most Recent
Frigidaire FVE145FF Upright Freezer Questions & Answers
Door left open for about 90 mins on freezer now
Good Morning Martin, thank you for your post!
If
the temperature of food rises to an unsafe level, the red light will glow.
First, deactivate the alarm to the unit by unplugging it or flipping the
household circuit breaker. Wait approximately ten minutes and then turn on the
unit. After deactivating the alarm and the unit has run approximately four
hours, the red light/alarm should go off on its own. If the red light/alarm
continues to stay on, the freezer may possibly have a communication problem
with the control board, temperature control or a wiring harness. If this is the
case, I would recommend connecting with an experienced technician to determine
the underlying cause.
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
I TRANSPORTED A REFRIGERATOR FROM HOUSTON TO
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
10/23/2019 10:37:05 AM •
Frigidaire...
Answered
on Oct 23, 2019
Where is the temperature control knob on Frigidaire upright freezer model #CFFH17F1RW
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
