20 Most Recent Panasonic PT-47WX53 47" Rear Projection HDTV Questions & Answers
9answers
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
9/22/2022 11:52:30 AM • Panasonic... • Answered on Sep 22, 2022
Sound not in sync with picture on some stations
indicates a sound board problem take it in for a proper diagnosis and quote
12/7/2017 7:30:07 AM • Panasonic... • Answered on Dec 07, 2017
0answers
3answers
PANASONIC VIERA TH50PZ85U 50" 1080P
your best repair is to find another one just like it and swap screens
4/3/2017 9:31:01 AM • Panasonic... • Answered on Apr 03, 2017
0answers
0answers
Codes for Phillips Universal remote clo35A
i have found the easiest way to get the codes to the clo35a model universal remote for phillips... go to the phillips website... here is the link that sends you directly to where you can get the codes. :)
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SRU3007/27&scy=US&slg=en#
7/1/2016 5:16:15 PM • Panasonic... • Answered on Jul 01, 2016
How do I upload a video to my PC?
The message about the AC adaptor is precautionary. Uploading a video can take quite a while. It would be disastrous to have the battery run out of juice before the operation is finished because the file would be ruined and you'd have to do it over again.
1/7/2015 5:48:29 AM • Panasonic... • Answered on Jan 07, 2015
How do I change the picture size back to wide screen
select the menu button then go to aspect ratio settings. choose wide or 4:3 option aspect ratio.
1/4/2015 11:46:28 PM • Panasonic... • Answered on Jan 04, 2015
Panasonic hdtv projection monitor tv no picture
Replace bulb
8/10/2014 2:19:10 PM • Panasonic... • Answered on Aug 10, 2014
2answers
How to remove yellow color in center of tv screen on pt-52lcx66-k panasonic hdtv
You might start by cleaning the lenses & mirror(this may use a Mylar sheet rather than mirror,don't try to clean the mylar) then install a new lamp part#: TY-LA1001 $70.00 http://www.tvpartsguy.com/servlet/the-11855/TV-Lamp-TY-dsh-LA1001-for/Detail or $49.00 to $80.00 http://www.shopjimmy.com/catalogsearch/result/?q=ty-la1001 If that doesn't cure it you most likely need a new light engine/optic block which would make the repairs cost prohibitive even if you can locate the light engine.
6/5/2014 6:26:59 PM • Panasonic... • Answered on Jun 05, 2014
first try cleaning all lenses & mirrors. Considering the age of unit you may need to replace cooling fluid in front of each CRT. I highly recommend a professional to do this if you consider it economically feasible. Possibly 1 or more CRT weak.
5/15/2014 2:34:35 PM • Panasonic... • Answered on May 15, 2014
FIVE BLINK
This is a trouble code. Check their website to see if it is a bad bulb, overtemp indication, or a power supply issue.
3/27/2014 12:57:51 AM • Panasonic... • Answered on Mar 27, 2014
When i turn on the my toshiba theater view tv all that happens is the of/on idicater light just flashes
We recommend you remove the "Digital In" cable connection from the rear of the TV and turn it back on. If the problem persists, we recommend having the TV evaluated by an authorized service center using the below link. www.panasonic.com/repair If the TV turns on then we recommend having the Toshiba Home Theater evaluated. Welcome to Panasonic Online Repair
3/26/2014 3:44:50 PM • Panasonic... • Answered on Mar 26, 2014
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Popular Tags
515 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
remove yellow color in center tv screen
  • Televison & Video
