20 Most Recent Panasonic PT-53WX54 53" Rear Projection HDTV Questions & Answers
2answers
I have a panasonic pt-53wx54 picture went black with a view vertical color lines then they went and it's now just black. sound is good no picture.. what do i need to do? thanks so much
This is one of several models that had a common problem.If set comes on with sound and you after a minute or two see a faint odd band of noise top to bottom on the screen to the right side C509 which is a .047 cap at 200 volts is bad.Cap is seen in attached photo(location marked and cap here gone).The cap when you locate it from the C509 number which is on top and bottom of board may have a crack or not---it is the cause of this problem.There is a hard way and a easy way to get at it--let me know and I will explain.3.00 part....................4_20_2012_7_24_56_pm.jpgPencil is point to location on Right side board seen from right side. 4_20_2012_7_26_02_pm.jpgThere are several brown caps here and some plugs here are removed.I would not try operation of the set in this condition too long.
3/22/2013 5:55:45 AM • Panasonic... • Answered on Mar 22, 2013
2answers
My tv is going crazy...major convergence problem
the convergence ICs are bad. replacing the ICs usually fixes it - they cost about 15 bucks each.
10/30/2012 4:44:22 PM • Panasonic... • Answered on Oct 30, 2012
Panasonic PT53WX54 error codes
two most common here are 3 which is short protection (usually convergence issue) or 5 that is short on 140 volt line inside the set in the sweep circuit.
10/26/2012 5:46:44 PM • Panasonic... • Answered on Oct 26, 2012
3answers
I have a PT-53WX54J and it has double image and
If you cannot move a certain color, red or blue then you may have more going on than just an adjustment.
What you might be experiencing based on your symptom sounds like a damaged convergence IC.
With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
12/9/2011 12:43:00 PM • Panasonic... • Answered on Dec 09, 2011
PT-53WX54 picture went fuzzy then disappeared,
If you have sound---the faint band is towards the right of the middle of the screen I know which part is bad it is very common on these sets and about a 3 dollar part.
If you want the answer and complete details rate this solution as very helpful as I do this here for free.
SD TECH
9/3/2011 12:34:01 PM • Panasonic... • Answered on Sep 03, 2011
Picture looks 3d colors not
The tv have a problems known as a convergence picture problems.That why ur tv colors lines R,G,B are mis alignments,have colors shadow pictures or have 3D pictures look alike?The tv convergence board it is dead.Tv Convergence board must have it parts like 2 STK convergence ICS and some or all of resistors to be replace too.To fixed the tv convergence board to solved tv picture convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
8/9/2011 2:11:19 AM • Panasonic... • Answered on Aug 09, 2011
My sound is working, but
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
I hope this will help in solving the problem....
6/12/2011 6:45:05 PM • Panasonic... • Answered on Jun 12, 2011
The red color is split in two cant get them back
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. Your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT's in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
How do I tell if the IC's are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC's. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC's and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC's located and how do I find them?
There are two and large IC's that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC's there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC's and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC's are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
I recommend the phone order so you can talk to the person about the different types of IC's that are available.
I would also advise that the convergence IC's be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC's fail after a short time, even though they look exactly like the OEM IC's. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
5/7/2011 5:42:18 AM • Panasonic... • Answered on May 07, 2011
Cant control the red convergence
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/30/2011 5:08:47 AM • Panasonic... • Answered on Apr 30, 2011
Top and bottom of screen
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
3/7/2011 3:45:10 AM • Panasonic... • Answered on Mar 07, 2011
How to convergence adj. correctly
download the user guide and use your remote. You may need the convergence amplifiers replaced.
This information is for someone that knows electronic.
1000s of volts inside the TV that can kill. Even if you unplug the TV the high voltage can be stored inside the TV for days.
Best of luck.
www.aaatvservice.com
3/4/2011 3:31:42 AM • Panasonic... • Answered on Mar 04, 2011
Hi Their, I have a Panasonic
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2/21/2011 4:16:23 AM • Panasonic... • Answered on Feb 21, 2011
Hi. I bought the set
Simple old age or any kind of electrical overload can cause a capacitor to fail in any number of spectacular fashions. Normally the electrolytic capacitors just puff up and bulge out the tops of their metal casings, or they crack open and ooze blackish gunk. But, if there is a serious power spike or some kind of short circuit, they can actually explode loudly like a capgun.
These days many everyday electronics are manufactured with inferior quality capacitors (especially on the power supply circuit boards) that fail regularly for no good reason, so finding a scorched capacitor in your set is not unusual. If there are any adjacent capacitors of similar size in that area of the circuit board, then there is a good chance that they are bad as well, even if they do not exhibit the same obvious signs of failure.
The good news is that they are fairly easy to replace if you have any skill with a soldering iron.
Just be sure to replace them with ones of equal capacitance (uF) and voltage rating (V), and make absolutely sure to install them with the correct polarity orientation (look for the + - or the white line down one side).
For replacement capacitors, it is ok to go a little higher on the voltage rating for the new one but never lower. And the capacitance value should be exactly the same as the old one.
For example, it's ok to replace an old 1000uF - 35V capacitor with a new 1000uF - 50V one, as long as it physically fits into the space available.
I cannot say for certain what caused that particular capacitor to fail but you can certainly replace it and see if the unit will then function.
Good luck.
If you have any questions or require any further assistance please comment back on this page and I will endeavour to help you.
If this was at all helpful please don't forget to click on the 4 Thumbs Up rating icon.
Thank you very much.
Joe.
2/18/2011 1:56:52 AM • Panasonic... • Answered on Feb 18, 2011
My pt47x54j went black during a movie. Light
YES, three blinks is error code for short protection. 98% of the time in this model it means one or both of the two STK-392-110 convergence chips is bad.
There is a easy way for you to confirm this. With the set unplugged remove the back cover. The two chips are 2 1/2 X 1 1/2 inches and black in color--they will have the STK-392-110 PRINTED ON THE FRONT OF THEM IN WHITE LETTERS.
They will be on Metal heat sinks with fins side by side.
What you want to look at is there are about a dozen light blue resistors around them--most will be marked 2.2 ohms.
Look carefully at the resistors--if even one is discolored or somewhat white in the middle you have found your problem.
They can be tested just like testing a fuse--should show as a short if you measure across them.
This repair involves replacing both chips and any bad 2.2 ohm resistors.
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET.
If you have some skill at soldering etc--the instructions will tell you everything you need and how to do the fix yourself.
Most shops are going to get 300 or more for this repair and some will not do it in the home.
You can buy a pair of the chips on Ebay (I can tell you the seller there I buy from) for about 12 dollars plus shipping---I have repaired hundreds of these sets--it takes about a hour or so.
Let me know if you want the instructions and I will post them here---
If this information has helped you rate this solution as I do this here for FREE.
SD TECH
1/11/2011 7:05:33 PM • Panasonic... • Answered on Jan 11, 2011
Keeps turning off and red light is blinking 3 time
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Thanks.
12/30/2010 5:58:20 PM • Panasonic... • Answered on Dec 30, 2010
My color is not perfect.
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
12/3/2010 5:36:58 PM • Panasonic... • Answered on Dec 03, 2010
2answers
What is convergence output circuit or convergence
They are pair of ICs that line up the image projected by the three CRTs. If they fail you will see ghosting(color behind color) images. The ICs cost 30$ for the two of them, +10$ for thermal grease and may be another 10$ for the resistors. The service charge is gonna be around 150-200$.
11/4/2010 1:39:27 AM • Panasonic... • Answered on Nov 04, 2010
Blinks 5 times with no picture
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
10/29/2010 6:11:44 AM • Panasonic... • Answered on Oct 29, 2010
The colors are seperated it almost looks like you
tylefalkner,
You have a bad convergence circuit. Not uncommon with older projection TVs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, where to get the parts and how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
10/19/2010 8:07:04 PM • Panasonic... • Answered on Oct 19, 2010
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
89 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
picture looks 3d colors not
  • Televison & Video
