20 Most Recent
Sony CDX-F5710 CD Player Questions & Answers
Need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Want to use ipod on cdx-f5710, how to fix it
use the aux lite input on the rear of the reciever. If it is a 3.5mm plug, you will need an extension with both ends male. One end in the aux port, on your head unit, the other end in the headphone jack of the ipod.
If it is RCA Aux lite, you need an rca-to-3.5mm adapter. Either item should be relatively cheap. $4-$5 USD
CD's are skipping
try cleaning the laser diode with an alcohol-soaked swab. be careful not to use too much alcohol or to press too hard against the diode lens.
Sony CDX-M850mp isnt playing any audio from aux or cd input
This issue might be due to a malfunctioning auxiliary input or a problem with the amplifier circuit. You can try the following steps to troubleshoot the issue:
- Check the connection between the auxiliary input and the head unit to make sure it's properly plugged in.
- Check the audio cable for any signs of damage or wear.
- Make sure the auxiliary input is selected as the source on the head unit.
- Check the amplifier circuit to see if it's functioning properly. If it's not, the amplifier may need to be repaired or replaced.
If these steps don't resolve the issue, it's recommended to have the unit inspected by a professional audio technician.
What is the correct way to hook up a 1000 watt Sony xplod Amp with 1 subwoofer to my Sony mp-40
To properly hook up your 1000 watt Sony Xplod Amp with one subwoofer to your Sony MP-40, you will need to connect the subwoofer to the amplifier using RCA cables. Once the subwoofer is connected, you will then need to use a power cable to connect the amplifier to your Sony MP-40. Make sure the power cable is connected properly and that the amplifier is turned on. After that, you should be able to adjust the settings on the amplifier to get the desired sound from the subwoofer.
My Sony GT90BT car radio is not working. No power on display.
usually one uses a power cycle in order to reset the radio. If the radio is not coming on, the wires powering it could be bad so you'd want to check them with a multimeter for current. Then, you'd want to test the car battery to see if it's still powerful enough to support all of the devices in your car. Then you can get the radio checked.
Thank you.
