20 Most Recent Sony KV-27S20 27" TV Questions & Answers
Remote
does the remote controller is the original remote for your tv ?. if yes and doesn't work the cause is either the IR sensor of the tv is get bad or has a problem in the board.
10/17/2012 7:03:12 AM • Sony KV-27S20... • Answered on Oct 17, 2012
Kv-27s20 fuse
if you open the back,follow the cord..theres the fuse. replace it,dont put the back on,plug it in...fuse blows right then. bad power supply.check on our site for parts and TVs http://www.shopjimmy.com/
9/6/2012 3:04:51 AM • Sony KV-27S20... • Answered on Sep 06, 2012
0answers
MY SONY TRINITRON KV-27S20 IS
Your TV needs demagnetizing. All tv repairmen have a demagnetizing coil to clear up the pictures on CRT tube televisions. It only takes about 10 seconds by waving the coil around and around in the front of the tube with the tv is on. Another possiblity (without my looking at the screen) is that there is a capacitor that filters the 200 volts to the socket of the tube that could be bad. However, it it is likely to need demagnetizing.
6/10/2011 3:24:22 AM • Sony KV-27S20... • Answered on Jun 10, 2011
I have a sony kv32s42. when plugged in the standby
green picture
12/21/2009 4:33:46 PM • Sony KV-27S20... • Answered on Dec 21, 2009
What is the width of the tv
this is a pin-amp section problum .
if your tech. pls check sum spare in Pin -amp section .
pin-amp ic / capaciter / pre-set .
( i think your tv set screen is low width and up or down corner is bend ) if yes then replace capaciter 10uf/63v non poler or Pin IC
10/6/2009 6:10:58 PM • Sony KV-27S20... • Answered on Oct 06, 2009
Tv no go
the circuit board will be damage as well , new tv is needed
9/1/2009 3:50:14 AM • Sony KV-27S20... • Answered on Sep 01, 2009
Sony KV-27S20 TV stays on channel 75 and will not change off this channel, video works fine, just can't change channel.What needs repair?
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
7/29/2009 10:19:29 AM • Sony KV-27S20... • Answered on Jul 29, 2009
Sony model # KV32S42. The TV started flashing when
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
5/5/2009 12:48:07 PM • Sony KV-27S20... • Answered on May 05, 2009
Dead
test the outlet you are using for the tv by plugging in another device like a blow dryer or a light. That way you can be sure u have power at the outlet.
2/26/2009 2:59:53 AM • Sony KV-27S20... • Answered on Feb 26, 2009
Is a Sony model kv-27s20 digitally ready
its only the one that have the code 4674w on the back and cover
1/26/2009 3:39:50 PM • Sony KV-27S20... • Answered on Jan 26, 2009
TV no pictuew
I have a sony trinitron kv35s40 and the problem is picture cuts off after a minute or so. We moved it to another room (it's really heavy 36") and it started with the problem.We live upstairs and can't bring it to a repair shop without a lot of effort.Please help What can it be?
7/16/2008 8:01:08 PM • Sony KV-27S20... • Answered on Jul 16, 2008
No picture or sound
Phillips Magnovox 50in I have an indicator light but no sound or picture. Any idea what the problem.
4/27/2008 12:28:25 PM • Sony KV-27S20... • Answered on Apr 27, 2008
Picture is squeezed into the top part of the screen
1) Solder pins of vertical output IC.........
2) Replace IC, if needed...................................T.
11/10/2007 1:46:06 AM • Sony KV-27S20... • Answered on Nov 10, 2007
2answers
How to find pins for the EHT and FBT.
Franko, If your sure about troubleshooting HI VOLTAGE then disconnect the horizontal output transistor first. Is it shorted? if it is get the fly and the transistor. But I wouldnt start it up with out a variac transformer. For the parts, go to http://www.partstore.com amd see what the parts cost or get the tele # and call them. BE CAREFULL. Good Luck
7/23/2007 5:24:21 AM • Sony KV-27S20... • Answered on Jul 23, 2007
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
1/13/2007 5:13:26 AM • Sony KV-27S20... • Answered on Jan 13, 2007
Flickering and then nothing
Well, seven years on a SONY is pretty good. These chassis have a good number of plugs and jacks on the main board. If you feel competent enough to open the back of the set, I'd go to Radio shack and buy a can of electronic components cleaner and a can of compressed air. Then, with the cover removed, find the plug that goes to the deflection coil on the neck of the tube. It should have four to six large wires on it. Disconnect the plug and lightly spray the EC cleaner on the plug and jack. If you have an old toothbrush, scrub the pins where they're exposed. Absorb any excess fluid with a paper towel and then blow the connctors dry with the air. Reassemble and test the set. If this doesn't work, your going to have to probe the other connectors with a wooden dowel rod while the set is on. PLEASE be careful around any High Voltage components! There's probably a good layer of dust inside the set as well. This layer can act as a blanket and cause components to overheat so carefully cleaning this out with a vacume wouldn't hurt. Hope this helps. Thanks for rating the solution.
11/20/2006 1:03:32 AM • Sony KV-27S20... • Answered on Nov 20, 2006
Black out tv after thunder rain
Is easy for them to say replace the main board,it will cost as much as a new tv or close,they say that because of the damage lighting or power surge causes and is unrepairable,some home owners insurance cover this damages and they just replace the equipment since is not worth repairing.You can call Sony just to see how much they want for a new board.Let Us know if you need any more information.
11/7/2006 9:08:12 PM • Sony KV-27S20... • Answered on Nov 07, 2006
Televison & Video Logo
Popular Tags
31 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
remote
  • Televison & Video
