20 Most Recent Sony KV-27FS12 27" TV Questions & Answers
I have a Sony kv-27fs12 the picture go out but you still can hear it and the standby light turns on first it flash 5 times then stop and do it again now flash continuously please if you know let me kn
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. If you want to know more about the blinking codes to Sony Brand TVs, check this link.
1/18/2013 5:06:39 PM • Sony KV-27FS12... • Answered on Jan 18, 2013
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
7/3/2012 4:55:06 PM • Sony KV-27FS12... • Answered on Jul 03, 2012
Bakit seksi ung screen?
What do you mean by this Bakit seksi ung screen. Send details of the fault. I can't understand it.
10/14/2010 6:18:26 AM • Sony KV-27FS12... • Answered on Oct 14, 2010
2answers
Menu won't show.
sounds actually like it has had weather damage, sometimes water can get into a place it shouldnt on a tv, not shorting it out, but instead messing up in your case the numbers or menu screen, so i'd say it is best to take it to tyour nearest recycler, hope this helps.......jason
3/6/2009 4:21:12 AM • Sony KV-27FS12... • Answered on Mar 06, 2009
Tv remote sensor gone crazy
bad switches behind front control buttons
10/29/2008 5:19:49 AM • Sony KV-27FS12... • Answered on Oct 29, 2008
Weird sound coming from the inside
TV needs some kind of service and dust inside to be removed.
Regarding sparks sound, it can be leakage of high voltage of Fly-back Transformer. Qualified tv technician can check and repair it as high voltage risk is involved here.
Thank you.
9/23/2008 3:49:21 PM • Sony KV-27FS12... • Answered on Sep 23, 2008
PIX GOES BLACK THEN IT COMES BACK THEN BLACK AGAIN
picture tube may be bad
1/2/2008 1:35:13 AM • Sony KV-27FS12... • Answered on Jan 02, 2008
Flyback serial?
The Sony part number for the flyback transformer is:
1-453-310-11
10/13/2007 4:15:26 AM • Sony KV-27FS12... • Answered on Oct 13, 2007
My Screen doesn't work
You can not find where the noise is coming but a service technician will know where to look and what to check.Get an estimate.
9/12/2006 7:25:14 PM • Sony KV-27FS12... • Answered on Sep 12, 2006
MY TV SONY KV27FS12 PICTURE PROBLEME
Hey Rolly no problem man as if we can help ya your not taking up our time as we answer when we can. Ok theres is still a small cap somewhere by the drive ic or they call it the jungle ic. If you have a schematic scan the vert part and I will assist you the best i know how.
4/14/2006 11:23:26 PM • Sony KV-27FS12... • Answered on Apr 14, 2006
3answers
PICTURE TROUBLE ON SONY TV ..KV-27FS12
most sony tubes bow in the corners, they just arent built that well
4/13/2006 9:23:10 PM • Sony KV-27FS12... • Answered on Apr 13, 2006
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Circuit diagram of sony kv-sz25m80
str no
2/26/2024 4:44:54 PM • Sony Televison &... • Answered on Feb 26, 2024
Sony KV-27FS12 27" TV Logo
18 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
when try turn sony kv 27fs12 keep turn
  • Televison & Video
