20 Most Recent Sony KP-61V90 61" Rear Projection Television Questions & Answers
0answers
Convergence ?
IF THE COLORS ON SCREEN ARE SEPARATED, OR BLURRY, OR YOU SEE SEPARATE COLORS ON SCREEN. DO A GOOGLE SEARCH AND YOU SHOULD FIND CONVERGENCE PROBLEMS ON TV'S AND WHAT IT LOOKS LIKE. THERE ARE CONVERGENCE KITS AND EASY INSTRUCTIONS.
11/17/2013 6:44:43 AM • Sony KP-61V90... • Answered on Nov 17, 2013
My t.v. led is bling on timer and standby
tried to disconnect the ac supply to the tv for a while. then plug it again and power it on hope it will back to normal. you can use the remote control then turn off the timer.
8/9/2013 1:22:26 AM • Sony KP-61V90... • Answered on Aug 09, 2013
Screen to dark
The 3 large lens (which can clearly be seen on Model indicated here can be cleaned) Look first to the lens and on this set from rear look up and inside at the mirror in the rear---lens are more common than the mirror.
12/17/2012 4:17:52 PM • Sony KP-61V90... • Answered on Dec 17, 2012
2answers
A chip on the circuit board started smoking
The component sounds like a resistor, and the fact that it was attached to a heat sink means its a power handling resistor. You said it was burning, so this means that whatever it is attached to is drawing too much current. From what you are saying a component on a board is drawing too much current and is causing another component (the 1 ohm resistor) to burn. My question is what board is this (I am suspecting the deflection or the HV power supply). Please post a picture of the board in question. That way I have a visual guide as to the board and if I can find the schematic, or if you can supply the schematic I'll be able to at least give a better diagnosis of this problem.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
8/21/2012 3:32:02 PM • Sony KP-61V90... • Answered on Aug 21, 2012
2answers
My sony kp-61v90 tv picture
Hello, It sounds like the deflection circuit is faulty. Usually,but not always caused by a problem with the switch mode power supply. It could be as simple as a capacitor or zener diode. Either way unless you are a technician I would get one to help you. Shouldnt cost any more than around $100-$180. As far as the pix goes,that sounds like the lamp they use to project images,around $400 fitted. Hope that helps.
6/8/2012 9:59:24 PM • Sony KP-61V90... • Answered on Jun 08, 2012
Color is seperating
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
3/24/2012 5:49:42 AM • Sony KP-61V90... • Answered on Mar 24, 2012
My Sony KP-61v90 has just
This set should have 2 RF inputs. Try hooking up to the B input and program the tuner again...
Let me know how that works for you.... Sincerely HDTV GURU JAY
3/16/2011 6:13:00 PM • Sony KP-61V90... • Answered on Mar 16, 2011
My sony tv modle kp61v90 is blurry , tried to
Try checking the solder where the RF (antenna in) connector attaches to PCB.
Found on: http://www.repairworld.com
12/27/2010 2:40:35 PM • Sony KP-61V90... • Answered on Dec 27, 2010
THE COLOR IS FADING ON MY KP-61V90 TELEVISION AND
If it still has the warrent you can return it and they check it out.
11/18/2010 7:28:50 AM • Sony KP-61V90... • Answered on Nov 18, 2010
The Blue color tube went out in my 2001 Sony rear
I just had one in for repair and CRTs are no longer available. If they were you will spend anywhere from $400- $600 for the repair.. Not worth it !
8/3/2010 9:51:27 PM • Sony KP-61V90... • Answered on Aug 03, 2010
0answers
Sony model # KDP-57WS550 just got green lines
A convergence amplifier I.C. has burned-out.
5/2/2010 12:27:08 AM • Sony KP-61V90... • Answered on May 02, 2010
The white seems to be sliding accross the screen
You could unplug it; remove the lower back panel; and dust-off the lenses in the top.
4/14/2010 1:03:42 AM • Sony KP-61V90... • Answered on Apr 14, 2010
Sony KP-61V90 61" Rear Projection Television Logo
Popular Tags
76 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kp 61v60 seem problem
  • Televison & Video
