20 Most Recent
Sony KP-48S35 48" Rear Projection Television Questions & Answers
I have a Sony KP-48S35, Rear Projection TV and the
i would say the bulb is on its way out and needs changing. on the back there is a hatch with one screw remove the screw and unclip the bulb holder, then pull out by the handle part number is on the bulb housing or the tv case.
When i turn the tv
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
TV blinks every 5 mins
the tv is telling you that the crt bias is incorrect, if i'm right the auto focus will stop part way through.
Sony kp 48s35 front screen broken
http://www.partstore.com/Part/Sony/Sony/KP48S35/Sony/Sony/408470101/New.aspx
this is the link for the fresnel screen but i myself am trying to find the lenticular screen but so far no luck
No Picutre
someone shot your tv.
no really, I am just a smart a$$ --- but the loud pop sounds like it may have been one of the capacitors in the power supply board. check for a POPPED cap (rare) and if there is one, test the components in the related circuit - as SOMETHING had to happen to make a cap fail like that - maybe a voltage regulator? give it a look..
Sony KP-48S35 Picture
Since this recovers on its own, there are a few possibilities:
1) There are bad connections on the board that self-correct as the unit heats up a bit.
2) There are capacitors in the convergence and pincushion circuits that are starting to fail.
If you can solder, you can repair this yourself. First look for poor solder connections that appear to be grainy or have rings and resolder them. If that fails to resolve the problem, we next have to look for failing capacitors. I will look up the most probable caps in both circuits and post the circuit designations here.
Keep up posted on your progress.
Dan
